Fuel lines
Discussion in 'High Tech Retrofits' started by 408maro, Feb 9, 2016.
  1. hot72rod
    3,017
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I have flex line at the front running up to motor, one just under the passenger seat were the factory you rubber line, one coming off the hard line to the filter and then 2 more from filter to the tank.
    Now if you wanted to get a little cheaper with this, you can use EFI rated rubber line in place of the flex line for a fraction of the cost.
    I bought 25 ft of flex line and used all but may 3ft, but one thing you have to take into account is I used a Tank's Inc tank. If you are going to use the Spectra tank, I don't see maybe using 7ft of hose.
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I have a Rick's Tank that I bought from another member here.
    Just curious, why does it matter if you use a Spectra tank vs a Tank's Inc tank with respect to the amount of flex line used?
  3. hot72rod
    3,017
    39
    Aug 9, 2000
    That's easy to answer. The spectra EFI tank has metal lines that come from the pickup and run along the front edge to the passenger side like an original tank. The Tank's Inc tank is probably more like the Rick's tank.
  4. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    great info here guys... thank you very much for the replys and the suggestions
  5. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I like easy answers, thanks.
    I assume similar (or the same?) compression style fittings are used on the flex line?
  6. hot72rod
    3,017
    39
    Aug 9, 2000
    Correct again
  7. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    hot damn, I am going to go play the lottery
  8. 1934chevycoupe
    1934chevycoupe Veteran Member
    270
    Mar 12, 2013
    Harleysville, Pa
    so while we're talking about what kind of fuel line to run, where are ya'll locating your regulator-filter? i got the corvette all in one regulator-filter. i was thinking straight above the gas tank outlet ( Tanks tank), but then i think i should wait till i get the exhaust in.
  9. hot72rod
    3,017
    39
    Aug 9, 2000
    Do I get a dollar when you do.
  10. hot72rod
    3,017
    39
    Aug 9, 2000
    If you go back and look at my pic you can see mine is located just forward of the sway bar link mount on the inboard side of the frame rail.
