Fuel lines
Discussion in 'High Tech Retrofits' started by 408maro, Feb 9, 2016.
  1. 1934chevycoupe
    1934chevycoupe Veteran Member
    270
    Mar 12, 2013
    Harleysville, Pa
    i can see where you're transitioning to flex, but i can't figure out where that reg.-filter is mounted. it looks like it's mounted to the side of the rear frame rail, maybe at the right front corner of the tank?
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    hell, I will give you TWO dollars
  3. hot72rod
    3,017
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    Sorry I didn't post these yesterday.
  4. hot72rod
    3,017
    39
    Aug 9, 2000
    Now if I was to use the spectra tank I would use the bolt hole just in front of the sway bar drop link.
  5. 1934chevycoupe
    270
    Mar 12, 2013
    Harleysville, Pa
    thanks, now i can see where it's at. just needed a further away view.
  6. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    Not the factory lines, no chance. Just pulled the lines from the latest donor car, a 1995 roadmaster wagon, and the lines are like new as they always are. No UV exposure, they do not degrade.
