Fuel pump EFI - Internal or External, Pros, Cons??
Discussion in 'High Tech Retrofits' started by Aceshigh, May 4, 2006.
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Thanks, i'll ask about that.
  2. Nutt
    Nutt Member
    65
    Mar 13, 2002
    Whiteman AFB, MO
    This may be easier, and cheaper!
    In-tank pump that's not in the tank. Easy to get to...
    http://www.geocities.com/hrayhouston/antisurgetank.html
    edit- oops. my bad. late night. LS1 so no mechanical pump. You can use this setup temporarily if you had an electric puller (carb) pump feeding this one.
  3. ZedMan
    ZedMan Veteran Member
    178
    Dec 15, 2004
    Calgary, AB, CA
    With an anti-surge tank, how would you make sure that the tank does not overfill or is drained completely? Would the two pumps have to matched? (ie. both 110gph, one at 45psi and one at 7psi?)
  4. OldSchoolFormula
    OldSchoolFormula Veteran Member
    119
    May 26, 2004
    Livermore
    You have a return line from the surge tank back to the main tank as well, so it can't overfill. I'd run a bigger low pressure supply pump than the high pressure pump to make sur ethe reservoir is always filled. Although, if they were matched, they'd probabaly be just fine. Even if if the high pressure pump pumps slightly more fuel than the low pressure, with the reserve in the surge tank it would take a while at continous WOT to drain it.
  5. 1st and goal
    1st and goal Veteran Member
    400
    Nov 5, 2005
    Seacoast, NH
    Don't cut the trunk for a "trap door", these tanks are very easy to drop as compared to a 4th gen which is a whore. I've done a few fuel pumps in 4th gens and they are a major PITA.
    I'd go with the intank pump ;)
    I know it's not really applicable but here are some pics of the twin intank fuel pump setup I fabbed for my 94 Z/28. I had a D-1 Pro Charger (19#'s of boost) on the car and the second pump kicked on via hobbs switch.
    http://www.geocities.com/marc94z/twins.html
    Good luck
  6. Doug Jaynes
    Doug Jaynes Veteran Member
    1,577
    Jun 2, 2000
    Michigan
    on my 70 I have a sumped tank that I mounted a Walbro 340 pump to sit down in the sump and its plumbed out thru the top. works great.
  7. OldSchoolFormula
    119
    May 26, 2004
    Livermore
    Mike, what did you do for the sending unit? I don't have a 3rd gen sender at the moment, but looking at how the 2nd gen sending unit is attached to the feed tube, I don't see how it would have any room to do its job with the 3" pipe. I really wish you had a pic! LoL
