Fuel pump help
Discussion in 'Engine Topic' started by 5spd540, Jul 14, 2019 at 6:00 AM.
  1. 5spd540
    12,354
    13
    Sep 19, 2009
    Guyton, GA
    I have a 79 camaro I just put the motor in but it’s a mid 90s 350 without a mech fuel pump boss. What electric fuel pump would you recommend and do I need to run a return line and if so how do I do that? Been out of a camaro for 7 years. The motor is only a 260 horse motor but just want to get it going so I can do the bodywork then put a new motor and trans in it.
  2. CorkyE
    10,063
    371
    Assuming this is going to be a low psi carburetor setup? Both Carter and Holley make a slew of pumps that will work without a return line or regulator. I had good luck with my last Carter pump. Just remember when selecting a mounting point that electric pumps push gas and are not very efficient at drawing gas like the mechanical ones. Holley has some fairly new inline electric pumps that might work, I don't have any experience with them.
  3. 5spd540
    12,354
    13
    Sep 19, 2009
    Guyton, GA
    Yes it has a Holley 600 on it. I was thinking of a carter p4070
  4. Z28zz383
    Z28zz383 Veteran Member
    801
    May 11, 2012
    Florida
    I have a 4070 from napa. (same pump) Mounted under the outside trunk area on the passenger side. i used some tire sidewall pcs to isolate it, Works great with my 383 stroker. Need to run a power circuit thru the oil pressure switch for safety. (in case of crash) I have a momentary priming switch for initial startup. Fairly quiet and provides plenty of fuel at 50 GPH.
  5. 1980RS
    1980RS Veteran Member
    2,931
    398
    Jun 17, 2006
    MN
    I run a Mallory Comp 140 on my street car (electric) I figured the one on the race car has gone almost 30 years so that good enough for me.
  6. cadillac_al
    cadillac_al Veteran Member
    775
    67
    Apr 22, 2015
    Maine
    GM Performance Parts catalog sells a nice one.
  7. COPO
    17,295
    495
    Toronto, Ontario, Canada
    That year should already have a return line.
  8. tom3
    tom3 Veteran Member
    11,668
    264
    Aug 1, 1999
    ohio
    Just don't buy one of those $15 dollar inline pumps. Get you about ten miles from home when they quit.
  9. CorkyE
    10,063
    371
    Sounds like the voice of experience. :)
