Fuel tank straps
Discussion in 'High Tech Retrofits' started by 75Maro, Jul 11, 2019.
  1. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
    just installed a ricks restomod tank in place of my factory 1970 tank.
    Spoke with ricks and was informed that the factory straps would work with their tank. The factory straps are about 4” to short.
    Has anyone ran into this problem?
    Thanks !
  2. mrfleet12
    mrfleet12 Veteran Member
    356
    111
    Aug 8, 2014
    West of Chicago IL
    I didn't use the Rick's, mines a Tanks brand, stock straps were too short, I used the ones that came with the Tanks setup..
  3. 75Maro
    435
    18
    Mar 31, 2008
    Dallas,Tx
    That’s what I expected but before purchase I spoke with them and they said stock straps would fit. Looking on their website they don’t even sell straps!
  4. badazz81z28
    17,143
    555
    Las Vegas, NV
    Why would you want to use the stock straps? With a SS tank, use the SS straps
    They don’t list straps because there’s no reason to. The tanks come with straps abs if you have an issue, you can just call them for replacements.
    dave@ztech likes this.
  5. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    If it came with straps , I would think he would have mentioned, and I hate Rick's I think they have the highest prices, and BA is correct, it says the EFI conversion tank comes with straps
  6. badazz81z28
    17,143
    555
    Las Vegas, NV
    I have bought about 4 Ricks tanks over the years. My appeal to them is the use of the 5th gen modules and corner pick-ups. My last tank was made the way I felt I needed it to clear my exhaust. They are expensive though.
  7. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Are you sure the straps are short? Reason I ask is if you take brand new factory style straps and try to use them for the first time you would swear they were too short, but after they assume the correct shape of the tank they fit fine.
  8. badazz81z28
    17,143
    555
    Las Vegas, NV
    ^^ yeah, but not 4”. If You can’t even get a bolt or nut started they are too short.
  9. 75Maro
    435
    18
    Mar 31, 2008
    Dallas,Tx
    The restomod tank from ricks is not stainless steel.
    It did not come with tank straps, I called Ricks before I purchased and asked about the straps and they said the tank did not come with straps because the stock straps would fit.
    I agree 100%, when i put the straps on the original tank i had to fight them to make them fit.
    This time the straps aren't even close.
    John Wright likes this.
  10. 75Maro
    435
    18
    Mar 31, 2008
    Dallas,Tx
    Just got off the horn with Ricks again, now they say it (the tank) should have come with straps cause its a bit larger than factory. o_O
