Fuel tanks
Discussion in 'High Tech Retrofits' started by RaycerX81, Aug 22, 2009.
  1. RaycerX81
    RaycerX81 Veteran Member
    552
    Dec 11, 2004
    Hayward, Ca.
    Im just curious about what some of you guys did for your tanks for the LT/LS powertrains. Post up pics. Im trying to get an idea.
  2. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    Mine is just a standard small block, but since I'm going EFI it's the same as if I went Gen II or III.
    I had a stock tank modified with a baffle and an in-tank pump. The pump is a Walbro 255 lb/hr pump, but is designed for 65 psi. It is similar to the LS1 pumps, but actually made for a Ford app. The company that did the work said they had problems with the LS1 pumps and this was more reliable.
    I believe Spectra is the name of another company that is selling tanks already set up for EFI. Do a search going back around a year and you should find a few threads on them. I don't know of anyone running one of them yet, but they are very affordable.
  3. cubs2008
    cubs2008 Veteran Member
    245
    Jul 30, 2008
    Chicago, IL
  4. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    spectra only sells tanks for the pre 74s unfortunately, else I would already have one in my 76
  5. theflash
    11,040
    34
    Feb 27, 2004
    Podunk, CT
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Yep.
    Sameplace I sent my tank to be modified.
    I got my tank itself from Tamraz Auto Parts locally.
    IIRC Tank was $~100-200 and the Modification with pump installed was ~$475.
    Cheaper IIRC then buying a stainless tank from them.
    They didn't seal the tank correctly and paid the shipping BACK to them
    and then BACK to me after repairing it. Great customer service. A+++
  7. RaycerX81
    552
    Dec 11, 2004
    Hayward, Ca.
    has anyone tried to retro fit any other efi car fuel tank.
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Be more specific....
    What tank.....what car.... ??
    Any tank can be modified to work with EFI.
  9. RaycerX81
    552
    Dec 11, 2004
    Hayward, Ca.
    ANY GM car that came with EFI from the factory. Has anyone tried to retro fit a tank from one in to a camaro.
  10. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I was looking into a mid 80s Monte or Regal with the turbo engine. The tank
    measures to be "about" the same, just a bit smaller, but deeper. I think it is
    going to interfere with the rear mounted single muffler. I couldnt find one in
    the junk yard to measure, just an early 80s carbed model.
    Tom
