Fuel tanks
Discussion in 'High Tech Retrofits' started by RaycerX81, Aug 22, 2009.
  1. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Problem is, its not a baffled tank, does that little tray solve the fuel starving
    on turns and takeoffs?
    Tom
  2. SomeGeoffGuy
    SomeGeoffGuy New Member
    22
    Mar 15, 2010
    Metro Detroit
    Is there some kind of drop-in baffle we could use? Or, the late GM fuel hanger assemblies use a "jet pump" to keep fuel inside the tank hanger pocket to keep it from cavitating. Maybe one of those would drop in. Anyone have an unmodified one laying around?
    -Geoff
  3. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
  4. SomeGeoffGuy
    22
    Mar 15, 2010
    Metro Detroit
    Thank you for the links! That tanks inc baffle looks pretty good actually. It doesn't need to be anything fancy, plus it looks like they plum the return line into the baffle pan so it should stay pretty wet in there. Maybe if I sumped the tank with one of those Summit sump kits, then put the tanks inc baffle down inside of it. Hmmm...
    -Geoff
  5. motown 454
    motown 454 Veteran Member
    414
    Feb 4, 2008
    Ma.
    I'm doing an Aeromotive universal sump for my 69 tank with an out side Weldon 1100 A pump. It won't need to but it has the ability to suck fuel from the tank a short distance. Her's the sump http://www.summitracing.com/search/...sal-Baffled-Fuel-Tank-Sump-Kits/?autoview=sku
    I can't weld or fabricate but from what I see here a lot of you guys can make your own. The install instructions are on Aeromotives site. A member on PT Mkelcy has this in his car and said it works fine.
