Fuse box diagram?
Discussion in 'Electrical Systems' started by anderson8687, Mar 25, 2012.
  1. Twisted_Metal
    24,944
    183
  2. Kamaro
    Kamaro Veteran Member
    259
    Oct 31, 2010
    Doha
  3. Domobomb
    Domobomb Veteran Member
    188
    Nov 10, 2009
    Windsor, Ontario
    Thanks, I've seen this. But is there any diagrams that show which wires are hot, and at what time?
  4. Twisted_Metal
    24,944
    183
    The most sure-fire method to determine the answer to that question is to use a probe circuit tester with the key in the "Run" position.
    Every fuse block contact should have power EXCEPT the instrument lamps circuit.
    (That one gets power from the headlight switch.)
    Then... Turn the car off and see which contacts still have power.
    Those are your "BATTery" circuits.
    Next.... Pull the closest fuse to see if it controls the contact you want to use.
    When you find it.... Look at the fuse rating.
  5. Domobomb
    188
    Nov 10, 2009
    Windsor, Ontario
    Thanks for the tips!
