gas gauge
Discussion in 'Troubleshooting & Diagnosis' started by Scrappy1980, Nov 7, 2019.
  1. Scrappy1980
    Scrappy1980 Member
    66
    Jul 17, 2019
    My gas gauge was working fine one minute and not the next, it is going way past the F almost to the middle. Is there anything i should check out before dropping the fuel tank?
  2. grzewnicki
    3,330
    118
    Dec 9, 2009
    Gordon from Jacksonville Fl
  3. Twisted_Metal
    26,944
    925
    ^+1
    You have an open circuit. (At the sending unit ground or the wire to the sending unit.)
    A gas gauge is an Ohm meter, it measures electrical resistance at the sending unit.
    Reading "Past Full" shows the resistance is "infinite", meaning you have a bad connection.
    Dave Nelson likes this.
  4. Scrappy1980
    Scrappy1980 Member
    66
    Jul 17, 2019
    Thanks,you all have given me a starting point. Why do i know deep down inside it will be at the tank?
  5. Twisted_Metal
    26,944
    925
    Look for the black ground wire coming from the top of the tank and check its connection to the body first.
    (It's the easiest part of that circuit to repair.)
  6. Gary S
    22,409
    751
    Also, check the wiring connector inside the trunk. The open circuit could be there.
  7. grzewnicki
    3,330
    118
    Dec 9, 2009
    The ground wire for the sending unit is under the filler neck and towards the passenger side (at least on a 1972), It has a small sheet metal bolt that holds it to body skin, it is connected to the sender by a little crimp tab built onto the body of the sender, if you have an ohm meter you can check the end of the ground wire (disconnected from body now) to the body of the fuel tank, you should have continuity, you can also disconnect the tan wire inside the trunk where it exits on the sheet metal hump and check it through the sender to the end of the ground wire. On the fuse panel there is a long skinny connector that clips in, that is your harness to the rear of the car, you can check the tan wire there all the way to the end of the ground wire (again disconnected from car body) and see if you have continuity. That will verify everything from that connector through the sender to the end of the ground wire is good.
