Gauge Cluster Lights
Discussion in 'Electrical Systems' started by 71smalbloc, Jan 7, 2019.
  1. 71smalbloc
    71smalbloc Member
    41
    Jan 6, 2016
    Blacksburg, VA
    Does anyone with an early 2nd gen have a picture of their dash with the background cluster lights on? I recently replaced all of the bulbs and the circuit board on my '71 and there is a dark region at the left side of the tachometer. I swapped bulbs around with known good ones and still nothing. I'm wondering if it's like that from the factory.
    Thanks
  2. Twisted_Metal
    26,550
    726
    Did you clean the contacts on the sockets? (internal and external contacts)
    It only takes a little corrosion to prevent the wire contacts on the bulb from functioning.
    (There are 6 bulbs for background lighting in these clusters.)
  3. grzewnicki
    3,105
    48
    Dec 9, 2009
    Gordon from Jacksonville Fl
    May be a bad bulb holder also, contacts on them can have a bit of corrosion, swap with a known good bulb and holder to see if that fixes it.
  4. 71smalbloc
    71smalbloc Member
    41
    Jan 6, 2016
    Blacksburg, VA
    All of the contacts look good but that doesn't mean they are. I'll swap holders and see what happens. Thanks.
  5. Twisted_Metal
    26,550
    726
    You've already eliminated most of the possible causes.
    The background lighting is all on one parallel circuit and you're getting power to the rest of the lights.
    That only leaves the bulb, socket contacts or a bad spot on the circuit panel where the socket makes contact.
    Good Luck!
  6. lozipone
    lozipone New Member
    Oct 9, 2014
    rochester,ny
    If they are led bulbs they are one directional. Turn them 180 degrees and try it. I installed them on my 72 and found that out.
    BillyDean7173 and Big Block Z like this.
  7. 71smalbloc
    71smalbloc Member
    41
    Jan 6, 2016
    Blacksburg, VA
    Turned out to be a bad socket. Thanks for the help!
  8. 71smalbloc
    71smalbloc Member
    41
    Jan 6, 2016
    Blacksburg, VA
    How do you like the LED's? Are they significantly brighter than the traditional bulbs?
  9. Twisted_Metal
    26,550
    726
    I installed LEDs several years ago (when they were $5 each).
    They work very well for the background lighting and turn signal indicators but they are overkill for the Hi-Beam indicator.
    (Unless you like a blue laser beam in your face while driving at night.)
    Background lights... I used these.
    https://www.ebay.com/itm/2-10X-T10-...hash=item467ebec88c:m:md8l0aWCQktbauobhBc3J5Q
    (10 for under $4.)
    There are literally hundreds of designs to choose from but you want bulbs which send light in all directions for background lighting.
    Use a bulb which is "forward firing" for turn signal indicators.
    (Big difference in the 79-81 clusters as the turn signal indicator relies on a plastic piece to redirect the light.)
    71smalbloc likes this.
