Gauge Marks oil pressure gauge not returning to zero
Discussion in 'Gauge Marks' started by flht99b, Jul 11, 2019.
  1. flht99b
    flht99b Veteran Member
    189
    32
    Nov 28, 2014
    Knoxville, TN
    I've notice lately my Gauge Mark oil pressure gauge doesn't return to zero with key off. Seems to work OK otherwise, hot 40 to 60lbs oil pressure. I just thought I remember it returning to zero when I turned off the car. Any ideas? TIA.
  2. CorkyE
    10,201
    414
    Disconnect it at the sensor, see what it does.
  3. flht99b
    189
    32
    Nov 28, 2014
    Knoxville, TN
    I believe I just never noticed this. Gauge sits at whatever the oil pressure was when car was shut off. Turn car back on and gauge returns to zero until engine starts and sender sees oil pressure. I believe normal operation, I just never took notice of it.
  4. 75Maro
    75Maro Veteran Member
    420
    17
    Mar 31, 2008
    Dallas,Tx
    I had a TA that used to do this. It was oil press, temp and tach that would stick and my OCD wouldn’t let me leave it like that. So I always had to cycle the key after shutting the car off so the gauges would “zero out”
    dave@ztech likes this.
  5. COPO
    17,623
    651
    I used to have my Stewart Warner 2-1/16" mechanical oil pressure gauge where the clock is. It fit perfect with sponge around the back side for support.
