Gear Drive to Double Roller
Discussion in 'Troubleshooting & Diagnosis' started by Tinfoil, Jul 29, 2018.
  1. Tinfoil
    Tinfoil New Member
    Jul 29, 2018
    Hi, first post here. I have a Blueprint 396 Stroker I just bought off a buddy. It's never been ran except for the dyno at Blueprint. It came with a gear drive on it, which I want to get rid of.
    My cam is: Roller
    .510 Intake .520 Exhaust
    230 Intake / 236 Exhaust duration
    @ .050, 110 ° lobe separation angle
    My question is (sorry if it's stupid), is there anything extra I have to do, other than pulling the gear off and putting on the new double roller? The reason I ask is, behind the gear on the cam you can see the block has been ground a little (see pic). Is that because the cam is a hydraulic roller?
    Also, when I go to a double roller timing chain; do you have any suggestions of type or brand? Thank you for any input. I'm a little new to the engine building community, thus, I may be asking rhetorical questions here.
  2. COPO
    16,999
    398
    When I installed a gear drive on a friends L78 I just removed the double roller parts and installed the Pete Jackson gear drive. Just do the reverse to go back. I've bought Edelbrock timing set and their gears are stamped GM. You can't go wrong with it or go with Cloyes brand. Cloyes also makes them for other companies such as Lunati. The grinding maybe was a clearance issue.
  3. Scott Sievers
    Scott Sievers Veteran Member
    129
    35
    May 22, 2018
    SE Iowa
    I have always used Cloyes. August of 2010 I shucked a cloyes double roller on my mud truck 383. October 2018, last run of the year my buddy shucked the double roller on his sbc 427. We both went to the gear drives, the quiet ones with no noise... okay, they still make noise but are not as obnoxious as the ones machined to make noise.
    Having said that, mine came apart at exactly 8433 rpm. (Mem Tach) and my buddies came apart at just over 8000 rpm... Since then I recommend OTHER timing options (Gears, belts etc.) on engines that will see high rpm.... Maybe a bad run from Cloyes? No idea. in 40 years of building engines I have never blown a Cloyes double roller, and they were all I would use. In engines that do not see high rpm's or heavy cam loads with big springs and high lifts I still use them, so... it is only my opinion that you should stick with the gears, unless your 396 stroker (Assuming small block?) is going to see more reasonable rpm's/loads?
  4. bourbon_scotch
    2,169
    81
    Jan 10, 2003
    USA
    you need that button on the timing cover for a roller
  5. Lowend
    14,753
    359
    Mar 25, 1999
    San Jose, CA, USA
    Yep - as long as you have the button, I believe everything else is a drop-in.
    Good on you for dumping the gear drive - those things are awful
  6. jeff swisher
    jeff swisher Veteran Member
    808
    186
    Apr 26, 2018
    There could be a cam retainer plate behind that gear. Not a hard thing to do.
    No need for a button if that is the case.
