Gear swaps.....should I put the 3.73's back in?
Discussion in 'Transmission & Driveline Topics' started by Millwright, May 15, 2019.
  1. Millwright
    Millwright Member
    49
    22
    Mar 30, 2019
    Ontario Canada
    I just bought a 73 LT Z28. The last owner did the restoration and overall its a nice car. one thing he did was replace the 3.73's with 3.42 gears to make it cruise better on the highway. Took the car out tonight and it goes but I can see that the bottom end could be improved. I live about 30 minutes out of town so the taller gears is a bonus running country highways pretty much everywhere I go.
    How much of a difference in bottom end performance would I see going back to the original gears (came with the car)?
    How much higher rpm am i going to see cruising on the highway?
    Engine is supposed to be around 350hp and has an M21 4 speed.
  2. badazz81z28
    16,165
    377
    Las Vegas, NV
    You’ll feel some difference with the 3.73s. It comes down to if the cost is worth the slight change. With a 2.20 first gear...I wouldn’t shy away from 4.10s if you’re looking for the 1st gear go.
  3. ULTM8Z
    ULTM8Z Veteran Member
    9,034
    286
    May 19, 2000
    Los Angeles
    What ever rpm you're cruising at, simply multiply it by the ratio of 3.73/3.42 and it'll tell you the new rpm.
  4. big gear head
    big gear head Veteran Member
    6,128
    63
    Jul 30, 2001
    Central City, Ky.
    The M21 is a bigger problem than the 3.42 gears. The M21 has a 2.20 first gear. Swapping to a M20 would give you a 2.52 first gear and would be more noticeable than the 3.73 swap, and still work pretty well on the highway.
    In the way of originality, keeping the original transmission and 3.73 gears would be the way to go.
  5. CorkyE
    10,108
    384
    I have 3.73 gears in mine and with a non overdrive transmission, keeping up with interstate traffic wasn't a lot of fun. I kept the gears and swapped in a 700-R4 transmission. FWIW - 3.73 was factory stock in later model 4 speed 2nd gen's. Here's a good set of calculators that can help. http://wallaceracing.com/Calculators.htm
  6. ZEN357
    ZEN357 Veteran Member
    360
    63
    Feb 12, 2018
  7. Gary S
    22,099
    648
    The gear difference between 3.42 and 3.73 is about 9%. So, you can expect about a 9% better launch with the 3.73 and 9% more rpms.
  8. badazz81z28
    16,165
    377
    Las Vegas, NV
    Exactly why many of us have 5 and 6 speeds. If you’re going to drive the car, with today’s speeds you gotta have OD.
  9. big gear head
    6,128
    63
    Jul 30, 2001
    Central City, Ky.
    Na, you just have to take your panties off and put on your big boy britches. I've been driving mine for 35 years with a 4 speed and 3.73s, 4.11s, and 3.70s at 70 and 80 MPH for hours at a time. That's the way they were back then and nobody cared. People are spoiled today with overdrive and low RPMs.
  10. Gary S
    22,099
    648
    big gear head is right. When these cars were new, we thought nothing of driving them all the way across the country at 4500 rpms. After all, they were built for it so why not enjoy them?
    The car can do it, can you? :)
