GEN 5 454
Discussion in 'Swap Meet Section' started by Rich Schmidt, Apr 17, 2019.
  1. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    Short block with heads,spotless inside about 40K miles on it. All apart but can be put right back together. I would ball hone the cylinders,have the crank polished and reassemble it. It has true flat top pistons with valve reliefs. $500 and you need to pick it up. I do not have the lifters,pushrods,rockers,tin etc. This was a flat tappet engine. Call me at 201-602-6076.
  2. 1980RS
    1980RS Veteran Member
    3,432
    601
    Jun 17, 2006
    MN
    If you were closer I would get that. good like with the sale.
    Rich Schmidt likes this.
