Gen IV LS Engine/4L80E swap into '73 Camaro
Discussion in 'High Tech Retrofits' started by jakeshoe, Aug 20, 2009.
  1. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    Here it is:
    New Jake's Performance LY6 Crate Engine and 4L80E going into a '73 Camaro.
    Highlights so far:
    6.0L iron block, L92 head engine, we're deleting the VVT and installing a performance cam. Custom built 4L80E, 9.5" 3200 converter.
    Edelbrock headers and mounts.
    Cadillac CTS-V oil pan.
  2. Todd80Z28
    11,690
    326
    Jun 11, 2002
    Northern VA
    Got any pan clearance shots? Didn't you say the engine had to set back an inch or two to fit that CTS-V pan?
  3. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    None of the pan in this car yet, we still have the truck pan on the engine. We have to do a cam swap and will swap the pan, timing cover, timing set, cam, and valve springs all in one shot.
    Ordering parts for that now.
    I've sold these pans to others doing the swap and they fit with the setback position, the Edelbrock mounts are setback.
  4. JAMMINJ007
    JAMMINJ007 Veteran Member
    397
    Dec 27, 2005
    Houston, Tx
    73
    Niiiiiiiiice!!!!! Car looks familiar:p
  5. driftwood
    driftwood Veteran Member
    2,026
    Mar 4, 2002
    07882, NJ
    I'm jealous.
    Does it look like the stock L92 intake will fit under the stock flat hood?
    Thanks, Joe
  6. JAMMINJ007
    397
    Dec 27, 2005
    Houston, Tx
    Hood
    Does not have a stock flat hood. It has a 4 inch cowl.;)
  7. victor3ranger
    victor3ranger Veteran Member
    1,048
    Sep 7, 2006
    Jake,
    Will the Eddy mounts work with a F-body factory pan??
  8. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    I'm not sure. I carry the CTS-V pans and they will usually fit where an F-body pan will so I typically use them.
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  10. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    Intake is the factory L92 intake. Truck configuration for the rectangular port L92/LS3 heads.
    I need to mark up my prices. I'm selling the LY6 complete as shown on the Mast site for $3K...
    Add a $700 cam kit, and a $1700 controller/harness and you have $3K less than they sell it for...
