Gen IV LS Engine/4L80E swap into '73 Camaro
Discussion in 'High Tech Retrofits' started by jakeshoe, Aug 20, 2009.
  1. LSXZ28
    LSXZ28 Veteran Member
    552
    Jul 17, 2009
    Crofton, MD
    That's a fact! The best prices around are from Wait4meperformance.com Ask for Jesse and you can tell him Bret from F-Body Central sent you. He can sell you a GM PCM with a stock tune or one tailored to your needs. His prices can't be beat!
  2. DB Z28
    DB Z28 Veteran Member
    567
    44
    Nov 30, 2003
    Fond Du Lac
    Could you measure from the fire wall to back of cylinder head clearance also could you also measure from front cylinder head to radatior support I,m getting ready to set in my ls-7as soon as its back from the dyno doing some new stuff to it. Need the measure making sure the coil bracket fits behind the head also making a billet dry sump tank holder that off the front of the engine so i don,t have to cut a hole down by the battery tray like a lot of people do with ther first gens thanks
  3. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    Why did you have to modify the cross member? What didn't clear? With the setback edelbrock mounts, did you have to mod the transmission cross member?
  4. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    The GM "aftermarket" ECM is locked but most "aftermarket" controllers are programmable.
    I'm looking at the M-90 from Mast for this combo.
    The stock GM ECM/TCM combo is about $400 shop cost to run the LY6/4L80E. Plus a harness, tuning, throttle pedal, assy.
  5. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    We didn't modify the frame crossmember.
    Regardless of what engine mounts or even engine you use, a 4L80E will require a custom transmission crossmember.
  6. driftwood
    driftwood Veteran Member
    2,026
    Mar 4, 2002
    07882, NJ
    By "GM aftermarket" ECM, are you reffering to the one in the GMPP controller kit?
    Thanks,Joe
  7. jakeshoe
    8,884
    21
    Dec 8, 2000
    Republic of Texas
    Yes,
    I wouldn't use it. Too limited at least at this time.
  8. 1970camaroRS
    2,606
    Mar 4, 2001
    Everett, WA
    Ah, I see. I'm going to be bolting mine to my existing 700r4. Read the instructions for the edelbrock mounts and they don't mention the need to modify the cross member. Guess I'm over thinking this.
    Here are the online instructions:
    http://www.edelbrock.com/automotive_new/misc/tech_center/install/6000/6701.pdf
    Interesting to note that for our cars edelbrock says the 12577901 (cts-v) oil pan is recomended. For all other cars the expensive milodon pan that requires a remote filter is required.
  9. driftwood
    2,026
    Mar 4, 2002
    07882, NJ
    Thanks, that saves me the trouble.
    Joe
  10. PolarBear
    1,189
    Apr 24, 2008
    NJ
    It seems that if you have access to a Tech II (from my understanding) you can put a VIN number in the GM "Aftermarket" ECM and then have the ability to program with any of the current tuning software programs.
