Gen IV LS Engine/4L80E swap into '73 Camaro
Discussion in 'High Tech Retrofits' started by jakeshoe, Aug 20, 2009.
  1. driftwood
    driftwood Veteran Member
    2,026
    Mar 4, 2002
    07882, NJ
    That's cool, I have access to the Tech II. I will have to look into this further before deciding which way to go.
    Thanks for the info, Joe
  2. 406chevyz28
    406chevyz28 Member
    71
    Apr 7, 2009
    ottawa
    You would also be putting a stock configuration program in at the same time as the VIN, you cant just program the vin separately to the PCM. After that i dont know about the aftermarket programming available to them, and you would also need a VIN to use.
  3. LSXZ28
    LSXZ28 Veteran Member
    552
    Jul 17, 2009
    Crofton, MD
    As far as I have found, the GMPP controllers are locked. The procedure of using a tech II and putting in a stock tune by the VIN is for a new GM factory controller (i.e. one for a vette, Fbody, truck, etc). The GMPP controllers are sold with intentions of them being used with the crate engine offerings and I was told they are locked...
