Getting ready to hit the track
Discussion in 'Competition Camaros' started by 76z28, Jul 27, 2017.
  1. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    Any tips or suggestions. Haven't really raced this big block set up at all.
    Car weights 3950 with me in it(I will get it down to an even 3900 come race day).
    Engine: 496 making about 650 horse
    Jegs 290 heads
    Edelbrock proflox 3 xt intake/fuel injection--1100cfm throttle body(picked up a few ponies based on the butt dyno from my victor jr which had previously picked up over an rpm air gap).
    250/256 @ .050 with .605/.620 lift (.15/.18 setting for lash right now)
    heddman headers 2" primary with 3" x pipe exhaust to bullets dumped before the axle.
    Th400 3800 stall
    3.73 in the back and some 275/60-15s for tires.
    I have cal trac bars--probably wont be able to get shocks for this outting but at some point will get a set of calvert shocks. Cal trac bars are set to be parallel with the ground.
    Plan on using MT drag radials or ET pros(What do you guys recommend?)
  2. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Missed how the rear diff is set up be prepared for a tow home.
  3. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    8.5 Moser 30 spline with Eaton posi and a girdle to keep caps from moving
    3.5 inch drive shade with solid 1350(if memory serves me) u joints
    Don't really understand the point of your comment though.
  4. Bandit723
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Did not look clear as to how your diff was set up have seen these go bad numerous times. From the sounds of it you will be good to go.
  5. CamaroGP
    CamaroGP Veteran Member
    691
    90
    Nov 10, 2012
    Summerfield, Florida
    Get'cha a fresh set of plugs Put them in before you head to the staging lanes and shut her off when when you go through the traps. Get a tow back to the pit or coast off to the side of the return road and check them. Gotta know what the Big Boy under the hood is do'n.
    76z28 likes this.
  6. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Didn't think of plugs, but Ill grab another set and clean the ones I have before I head up. With fuel injection I can smell it running well(like gun powder that went off)! Hope for mid 12s
  7. Turbo70Camaro
    2,146
    117
    Jan 7, 2005
    so cal
    Tires go with 295-55 or 275/60's depending on your wheel backspace..................
    TH400 don't even think about popping it in neutral after the stripe!!, plus your running FI your computer is the tuning guide although plug reading is a plus................
    Your mph will indicate what kind of power the car makes and I predict on a good pass should dip into the 11's.
    Most important have fun :bowtie:
    And read this from a few reputable transmission builders, it is a must...
    http://www.yellowbullet.com/forum/showthread.php?t=2261434
  8. camaro71/holland
    1,240
    87
    Aug 27, 2003
    The Netherlands
    This! Otherwise your planetaries might explode from overrevving.
    Also ALWAYS start your burn out in 2nd gear and finnish in 3rd.
  9. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Good luck & race safe.
    For the record, I only do high gear burnouts, and I have 17" monsters to break loose!!!!
  10. czizza
    czizza Veteran Member
    1,032
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    This combo with 650 hourse should get down to low 11's.
    I have 540hp at crank, 5spd and my best pass was 12.2 but blew 2nd gear so I should be high 11. My mph was 112.
