GM 260 horse engine?
Discussion in 'Engine Topic' started by 76z28, Nov 10, 2010.
  1. 76z28
    76z28 Veteran Member
    1,696
    Jun 29, 2009
    bakersfield
    What pistons does it have in it? im guessing dished? I have a set of pretty good heads only problem is they are 76cc chambers...Anyone know?
    thanks
  2. CorkyE
    8,817
    134
  3. 76z28
    1,696
    Jun 29, 2009
    bakersfield
    i went to jegs but it wouldn't load... i need to get the casting number off the head, they were in my old 330 horse 360 torque motor
  4. CorkyE
    8,817
    134
    If they are old GM cast 76cc heads, it doesn't matter... The bang for the buck seems to be with the vortec heads. I know you'll have to buy a new intake but it's still a better deal in the long run. Depending on how strong the wallet is, you can step up to modern aluminum designs for not a lot more. IMHO
  5. badazz81z28
    13,961
    91
    Las Vegas, NV
    Can't beat modern technology. I can vouch Vortecs are a good budget head. I have ported vortecs on my 350 and has enough power for a street go getter.
  6. BondoSpecial
    8,698
    Sep 20, 2004
    Southern Maryland
    They are not only dished, they are dished pistons that are 100+g heavier than even the normal 1970's stock 350 dished pistons. I had to have a lot of metal taken off my crank to balance my 260 hp crate motor when I put normal cheap pistons back in it, we couldn't believe how heavy the hecho en mexico crate motor slugs were. It's something like a 16cc dish.
    76cc pistons on the 260 hp crate motor is going to be very low compression. Even with 64cc heads it will only be around 9:1, which is why I pulled them for some flat tops.
  7. 76z28
    1,696
    Jun 29, 2009
    bakersfield
    Yea, that is why i was asking...I was afraid but make for a good blower motor untill the bottom end goes. I already have the heads and intake is why i was asking.
    Im just in speculation right now, this is for my dads 68 bel air(has the original 307)
  8. Damon
    Damon Veteran Member
    12,923
    13
    Nov 16, 2000
    Philly area
    ANY 350 will feel like you strapped a second engine under the hood compared to a stock 307!
    It's really a shame that GM doesn't offer any inexpensive 350 short blocks with flattop pistons (the ZZ4 bottom end which uses flattops is $2500). Or ANYTHING with forged pistons in it (they're all cast or hypereutectic).
    An observation I made recently.... the 260HP 350 LONG BLOCK is less money than just buying the SHORT BLOCK. Sounds crazy, I know, but that's what I found the last time I looked. Buy the complete engine and put your existing heads back on the shelf. Plus you get a cam, lifters, timing chain and the bottom end tin along with it. Saves money plus a bunch of work- just put on your intake and drop it in the car.
  9. z28rod
    z28rod Veteran Member
    4,473
    Apr 30, 2009
    hopewell junction,ny
    and it a reliable 350 to boot.....
  10. Todd80Z28
    10,848
    11
    Jun 11, 2002
    Northern VA
    Kinda, sorta. You can get the L31 (Vortec) 350 short block with similar-looking dished pistons for $11xx on the web, and my local dealer offered me $12xx. I've contemplated it for a new, budget solution. It's a one-piece rear seal, though.
    Like you said, though- it's a shame you can't get a budget flat-top setup from them.
