GM Dual Fans install into 2nd Gen **Pic Heavy**
Discussion in 'High Tech Retrofits' started by czizza, Oct 20, 2019.
  1. biker
    biker Veteran Member
    910
    94
    Dec 7, 2014
    New Liskeard Ontario Canada
    Very nice work. Maybe I missed it, but what was the original year/model application for those fans?
  2. czizza
    czizza Veteran Member
    1,026
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    The part# is in the first post. I believe the fans are from a 98 to 06 Fbody.
  3. biker
    910
    94
    Dec 7, 2014
    Ok thanks. Saw the part number, just didn't know what it was originally for.
  4. CorkyE
    10,379
    472
    I installed these fans also, virtual drop in for our cars. Used the original close out plate too, just some minor tweaking required. My wiring was a bit more complex since I'm letting the ProFlo 4 ecu control both fans. The ecu provides a ground for relays, so I installed a relay for each fan. I can set different temps for when I want each fan to come on. And to make it more complex, guy I had charge the a/c said I needed both fans coming on when the a/c was turned on, regardless of engine temp. So, one more relay was installed. It's working well though and doesn't look (too) shade tree like.
    mrfleet12 likes this.
  5. biker
    910
    94
    Dec 7, 2014
    Nice. I was researching that exact topic last night. I was hoping the proflo would control both fans. I may consult you again when I'm at that point in the spring.
  6. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    That is how I have mine installed(minus the ac part)
    Works awesome! I never have to worry about it.
  7. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,795
    102
    Aug 18, 2003
    On Wisconsin!
    Very nice write up
  8. ULTM8Z
    ULTM8Z Veteran Member
    9,185
    355
    May 19, 2000
    Los Angeles
    Yeah, AD244A here. 130 amps on mine and pretty much all of available at idle speeds. EFI, stereo, HID headlights, monstrous Ford Taurus electric fan, etc... never goes below 14.2V even at idle.
    AD244 is nearly a direct swap for a CS130.
    http://nastyz28.com/threads/ad244-alternator-upgrade.320800/#post-3657314
  9. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    I wouldn't say direct bolt in for these cars... Maybe later model. You have to find the right one with 12 and 6 ears. In my case the ad230 worked.
  10. amargari
    amargari Veteran Member
    1,236
    17
    Feb 19, 2003
    Morristown, NJ, USA
    What is the width and height of this assembly?
