GM Dual Fans install into 2nd Gen **Pic Heavy**
Discussion in 'High Tech Retrofits' started by czizza, Oct 20, 2019.
  1. czizza
    czizza Veteran Member
    1,032
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    Based on the part# search:
    • Radiator / Condenser Fan Motor Assembly
    • Rad / Cond Fan Assy.
    • Product Attributes:
      • Blade Material A: Plastic
      • Blade Material B : Plastic
      • Bolt Quantity: Oe Mount
      • Connector Gender: Female
      • Connector Type: 2 Terminal Connector
      • Description: Cooling Fan Assemblies
      • Electric or Mech?: Electrical
      • Fan Clutch Mounted?: Fan Clutch Not Mounted Within The Assembly.
      • Height IN:
        • 18.000
        • 18.500
      • Height MM: 457.200
      • Motor Type A: Radiator Fan Assembly
      • Mounting Hardware?: Not Included
      • Package Depth IN: 30.000
      • Package Depth MM: 762.000
      • Package Height IN: 6.000
      • Package Height MM: 152.400
      • Package Length IN: 20.500
      • Package Length MM: 520.700
      • Shroud Material: Plastic
      • Shroud?: Included
      • Style: Radiator Fan, Condenser Fan
      • Width IN:
        • 25.250
        • 25.500
      • Width MM: 641.350
    • OE fit and design; Motors built and tested to OE specifications; Quality construction and assembly; Out of box installation
  2. amargari
    amargari Veteran Member
    1,236
    17
    Feb 19, 2003
    Morristown, NJ, USA
    Thanks czizza
  3. 1980RS
    1980RS Veteran Member
    3,443
    602
    Jun 17, 2006
    MN
    What was that fan setup off of? or is it aftermarket?
  4. czizza
    1,032
    68
    Jan 8, 2004
    I believe 4th Gen Camaro, part# is on Page 1 of post.
    1980RS likes this.
  5. 1980RS
    3,443
    602
    Jun 17, 2006
    MN
    Thanks.
