Going from EFI to Carb, need help with pressure regulator.
Discussion in 'High Tech Retrofits' started by gutted72, Jul 22, 2019.
  1. gutted72
    gutted72 Veteran Member
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    I need some advise on getting the correct fuel pressure regulator.
    I am currently dealing with a screwed up sniper efi system and need to re-install my carb but I'm having a hard time choosing the correct fuel pressure regulator.
    I am going to use the current efi fuel pump in the tanks Inc tank that is currently putting out 60+ psi and I need to bring it down to 5 - 10 psi for the carb.
    I already have a 3/8" fuel return line installed on the car so I will be looking for a bypass regulator. I have come up with 2 that I think will work but I am clueless on if either will do what I need them to do.
    https://www.summitracing.com/parts/aei-13301
    https://www.summitracing.com/parts/edl-174053
    Tanks Inc recommeds the 174053 but I think the 13301 would be the better route to go.
    Any ideas? Anyone?
  2. 76z28
    76z28 Veteran Member
    1,982
    42
    Jun 29, 2009
    bakersfield
    I'd go with the edelbrock one. I can't imagine trying to adjust something that's 3 to 65lbs.
  3. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Thanks for the insight, didn't think they would be to hard to adjust but I've never installed a regulator. Plus that's the least expensive one :)
  4. 76z28
    1,982
    42
    Jun 29, 2009
    bakersfield
    I think with that range it might be difficult to do minute adjustments. I know the edelbrock one is a quality piece. I have theirs from the EFI kit and it has been flawless.
  5. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    I wonder how it will hold up to 60+ psi down to somewhere between 5-7psi?
  6. 76z28
    1,982
    42
    Jun 29, 2009
    bakersfield
    If you're running a return you should be fine since it'll just return everything
  7. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    It does have a return line installed on the car so that will be easy to hook up.
    Thanks for the help.
  8. 1978 Z/28
    1978 Z/28 Member Gold Member
    96
    22
    Jul 17, 2017
    New Brunswick
    I have much experience with regulators I can tell you adjustability would not be an issue. 13301 uses two different springs but I am not so sure about npt thread I like AN thread and o rings more. Less chance of leaks
  9. gutted72
    1,312
    128
    Mar 4, 2002
    Jennings, OK
    Other than the 2 I posted earlier, do you have any suggestions for a regulator that accepts 60+ psi inlet pressure and knocks it down to 5-9 psi outlet pressure & has AN fittings?
  10. 1978 Z/28
    96
    22
    Jul 17, 2017
    New Brunswick
