Good deal on new 4.8, 5.3, 6.0 LS engines
Discussion in 'High Tech Retrofits' started by Displaced Hokie, Dec 25, 2009.
  1. Todd80Z28
    11,671
    308
    Jun 11, 2002
    Northern VA
    So that's where they put the evap canister... I always wondered about that. Clever.
    That gives me an idea, actually...;)
  2. PolarBear
    1,189
    Apr 24, 2008
    NJ
    3rd and 4th gen tank are essentially the same.... I put a plastic 4th gen tank in my 91 direct bolt in, only "mod" you have to do is trim the rubber hose from the filler neck to the tank. I cut mine a little too short and the filler is too far down the hole. Still works though.
    My thought was to try to get a 4th gen tank in the back of my 71 somehow. Eventually I will get around to seeing what it will take to work.
  3. Doug Jaynes
    Doug Jaynes Veteran Member
    1,577
    Jun 2, 2000
    Michigan
    JJ, yes you can do the pump like you mentioned and it will work BUT .. with no baffle or sump to draw from it might suck air during hard cornering or breaking if the fuel tank is low on fuel.
    A friend of mine is an engineer at FAST that has a second gen that he just put an inline external pump on to feed a pretty stought sbc 550/600 hp with no trouble on casual cruising. Im sure he would admit he would rather have a sump but it works and hes a frugal guy. ha ha On my second gen , I have a morosso type sump welded in and I mounted a Walbro pump to sit in the sump and it has worked well for me (9.80 @138) For hard cornering it would probably hick up but for what I do, it works fine.
    Doug
  4. ErikNORCAL
    ErikNORCAL Veteran Member
    1,141
    12
    Aug 6, 2003
    now in VA
    The orange hotchkiss camaro with the LS1/T56 had a 4th gen tank. I seem to recall the write up mentioned they did something with the filler neck. Will have to dig around and see if there is an active link, I believe they have since sold it.
  5. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Scott from Hamilton, NJ
    Bear, if you have a 2nd gen tank bring it over soon and I'll drag out the plastic 4th gen tank I have to compare. I can't imagine the 4th gen tank working w/o big mods. See if btk or angry phil has a late 2nd gen tank.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Someone tried this before and put the 2 tanks side by side
    4th gen is narrower but taller. More boxy. 2nd gen is more pancaked rectangular
    4th gen tank on a 2nd gen would hang down and look bad from the rear IMO.
    But I'm just speculating.
    IIRC it's not going to work very well. I looked into this before I forked out the
    $500 + on the new tank and fuel pump mods.
  7. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Aces I agree I think big floor pan mods would be needed but for the curious we will research it.
  8. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I have the 4th gen tank I bought in the trunk of the 71 right now, lol. and a late tank wont help me, i need an early.... :confused:
  9. badazz81z28
    17,358
    598
    Alabama
    Ill have to see if I can get specifics from him.
  10. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Not trying to help you trying to help everyone here
