green bondo?
Discussion in 'Body Restoration' started by daniel76309, Jun 24, 2006.
  1. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    934
    Oct 22, 2005
    Niceville, Florida
    I have noticed on the tv show what appears to be a light green body filler. Does anyone know what that is? Is that superior to the pink bondo that I am familiar with? I mean, pink is cool, but...
  2. ChillPhatCat
    ChillPhatCat Veteran Member
    359
    Jun 9, 2005
    Ballston Spa, NY
    I've used "Bondo Hair" which is green before you mix it with the hardener, it's bondo with fiberglass resin and fiberglass strands added in... mostly good for covering gaps and higher stress areas. It's much harder to work with though, so I wouldn't use it for more than it's intended use.
    The pink color of regular bondo is caused by the hardener though, so maybe you're seeing a different color hardener being added to the bondo.
  3. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,673
    Dec 13, 1999
    Mission Viejo, CA, USA
    It's called Evercoat Gold (different company than Bondo). The filler is yellow, the hardener is blue.
  4. AceZ28_OVERKILL
    AceZ28_OVERKILL Veteran Member
    196
    Dec 25, 2004
    Walkerton, In, 46574
    A lot of FINISH muds are light green, also called metal glaze... Sands easier, and can be sanded out without leaving an ege where the filler stops and the metal begins...
  5. daniel76309
    934
    Oct 22, 2005
    Niceville, Florida
    Thanks for the replies. Whatever it is, they seem to be spreading it out over a large area, moreso than I would expect with all the metal work they seem to take pride in.
  6. Paint Fumes
    Paint Fumes Veteran Member
    488
    Aug 22, 2004
    Lots of fillers turn green when mixed with blue hardener. Spreading it out over a large panel isn't a bad thing to do as long as it's not too thick. It's called skim coating and it's done to get a panel totally wave free.
  7. nrjulin
    nrjulin Veteran Member
    130
    Oct 27, 2005
    Oxford, PA
  8. airzemee
    airzemee Veteran Member
    789
    Sep 21, 2003
    Regina, Sask., Canada
    yah.. a real good honest to god restoration shop will not use fillers like this.. they will take years on end to make that metal thats there perfect. SHows like overhaulin are seen doing this lots cause they only have a week or whatever.. Impossible to do metal work perfectly in that amount of time. When used right filler isnt a bad thing. I still dont like putting it over a HUGE area like on some of those shows. On overhauling it looks like they do a good job metal working it to put new panels and such. but thats not the finish. metal work finishing is whats time consuming even moreso. I should take pics of my project panel for when i was in school. Its a 24 by 24 inch square of flat steel.. I had to make a perfect dome shape in the metal using only a dolly, pick, and file. it took 2-3 weeks to do that alone. Granted it was my first time doing it and a pro could do it faster. but it still takes ALOT of time.
