Guys with ATS bracket and T56.......
Discussion in 'High Tech Retrofits' started by XxWickedz28xX, Apr 1, 2012.
  1. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,981
    May 22, 2001
    Carmel, NY
    What did you guys do with the brake pedal? Right now im using the factory pin, and the pedal is a bit lower than the clutch.
    Is it as easy as just drilling a new hole and using a bolt?
  2. PolarBear
    1,198
    Apr 24, 2008
    NJ
    I just left it lower, its really not a big deal
  3. XxWickedz28xX
    5,981
    May 22, 2001
    Carmel, NY
    I figured the 1/4" plate took some pedal travel away. My brake pedal felt a whole lot more firm before the swap, now it goes to the floor.
    Maybe the brakes need to bled more? Ugh
  4. Todd80Z28
    10,806
    Jun 11, 2002
    Northern VA
    I think some guys used an adjustable rod for the booster to take up the length.
    On the bleeding, I always get the best results by just letting it drip for a few minutes into a jar. Firmer than trying to use the pedal or my vacuum.
  5. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I bled mine by putting a 30" remote bleeder on mine, and elevating a bowl
    filled with brake fluid and pumping it until it was rock hard.
    Drill mod done prior. Can't testify how it performs yet though.....
  6. XxWickedz28xX
    5,981
    May 22, 2001
    Carmel, NY
    So i drilled a new hole in the pedal, gonna try and install it today and see how it feels.
    Changing the pushrod while the whole thing was out sounds like the move, i wish i thought of that. Unless it goes bad, i hope i never have to putz with that thing again!
    Sounds like i have some brake bleeding to do. :whine:
  7. woody80z28
    5,418
    11
    Sep 8, 2004
    walton, ny usa
    Mine did the same thing, and that's one of the reasons I converted to manual brakes with an adjustable pushrod.
  8. earlysecond
    earlysecond Veteran Member
    5,620
    Aug 9, 2002
    Altoona, PA
    I had the same problem. It is, at minimum, very annoying and hard to get used to. I need to re-visit the whole issue and come up with a better solution. My car is apart and this issue needs attention before the fender goes back on !
  9. XxWickedz28xX
    5,981
    May 22, 2001
    Carmel, NY
    Yeah its annoying. I drilled a new hole in the brake pedal, just not crazy about that idea long term.
  10. banaro79
    banaro79 Veteran Member
    268
    Dec 27, 2010
    hamilton, new jersey
    I drilled a new hole and welded it back in I'm gonna double check tho
