Hand cleaner
Discussion in 'Tips 'n' Tricks Topic' started by KWIK 73, Apr 26, 2002.
  1. KWIK 73
    KWIK 73 Veteran Member
    1,851
    Feb 25, 2002
    Missouri
    What's the best hand cleaner?
    For grease or paint on my hands, I use a shot of PB Blaster to loosen it all, then some Gojo Orange cleaner. End results = clean hands.
    73 Camaro RS, LT Type
  2. CoryM
    CoryM Veteran Member
    1,542
    Jul 23, 2001
    Vancouver, BC, Canada
    At home I use pretty well any soap that will cut grease and a little coarse sandblasting sand. Will find out what the name of the stuff at work is, works better than anything I have ever seen. Brake clean works pretty good too [​IMG].
    CoryM
    1980 Camaro, daily driver but fixing it up as fast as I can.
    70 C10 350ci,np354,4:10 posi www.geocities.com/chevroletc1070
    Vancouver BC Canada.
    "Take up our quarrel with the foe:
    To you from failing hands we throw
    The torch; be yours to hold it high."
    Lieutenant Colonel John McCrae, Canadian Army
  3. z2880
    z2880 Veteran Member
    1,340
    61
    Jan 3, 2002
    Tewksbury, ma, usa
    i like fast orange. works good, or theres always sandpaper [​IMG]
    is any car actually finished??
    -Blake-
  4. 79camaro305
    79camaro305 Veteran Member
    1,746
    Jul 8, 2001
    Hainesport, NJ USA
    I have yet to find any hand cleaner that actually cleans my hands. The so-called "industrial" cleaners work better than normal soap, but I still can't find anything to get off most of the grease/oil. Oh well, hopefully one of you guys know of a good hand cleaner
    79 w/305 & Sunroof?
    81 w/229, Dual Flows, T-tops
    Beautify America. Drive a Camaro
  5. FSEVENTY
    FSEVENTY Veteran Member
    1,071
    Jan 31, 2001
    Mesa, AZ USA
    Powdered Laundry detergent. It's cheap, always around, and the coarsness of the flakes helps to scrub off the grime. I worked for a mechanic in college who taught me this. Unfortunately, he bought the bottom of the barrel stuff, and my hands got pretty raw somedays.
    1970 RS
    350, 700R4, 3.73 posi
    2 yr. old loves to cruse with me.
    I ride with <><
    Pic of "Dada Racecar"
  6. Psychohamster
    Psychohamster Veteran Member
    9,058
    Oct 22, 2001
    Redwood City, CA. USA
    I usually wear surgical gloves while wrenching, but when my hands get really dirty I wash them in my parts washer, then soap and water then use some type of hand creme to replace the natural oils.
  7. MikeM79
    MikeM79 Moderator Lifetime Gold Member
    7,022
    Mar 5, 1999
    East Quogue, NY
    An ounce of prevention....
    Most parts stores sell this stuff you can put on your hands before you begin working (I think it is called "Invisble Glove"). Anyway, it coats your hands with some stuff that makes removing the grime very easy when you are done. I have also become a big user of those "Mechanics" gloves while working. When done I use a non-gritty type hand cleaner and a nail brush. Works for me.
  8. KWIK 73
    1,851
    Feb 25, 2002
    Missouri
    yep, the GoJo Orange cleaner I spoke of comes with a nail cleaner attached to the side of the bottle, too.
    It's actually the PB Blaster lubricant stuff that does all the cleaning. Spray on and the grease drips off. I don't know what that stuff is made of, or where it originally came from, but I wouldn't be suprised to find out it originated from the Roswell, New Mexico area.
  9. CoryM
    1,542
    Jul 23, 2001
    Ok, the stuff at work is called "thorgon". We buy it by the bucket so I dont know what the retail name is. Compared to this stuff Fast orange is a Surrey girl (it sucks! [​IMG])
    I think the real trick is to wash your hands a few times a day. I wash mine everytime I finish a car. If you are doing a real slimy job the ONLY way to go home with clean hands is to wear gloves from what I have found.
    Have Fun.
    CoryM
  10. Morkai
    Morkai Veteran Member
    1,250
    May 8, 2001
    Tifton, Ga USA
    I just use regular old original GOJO, it cuts greese good. Most of the time it'll just drip off too, but the key is not to wet your hands first. GOJO works best dry. Then wash with regular soap to get the GOJO off good. [​IMG]
    Eric aka(Morkai)
    '79 Z28, Silver, T-Tops, 388-roller...back on the engine stand ;)
    "186,000 miles a second, it's not just a good idea... it's the law."
