Hanging front end panels, best order of operation?
Discussion in 'Body Restoration' started by Ferg1031, Dec 31, 2016.
  1. Ferg1031
    Ferg1031 Member
    38
    May 2, 2016
    Portland, OR
    Got rid of all the re-pop crap on my 78' for all original metal. My buddy and I did it with no real body panel hanging experience. Most things lined up ok, the hood however was done last and is being a pain. Is there a "best order of operation" to make such things easier? Or, any tips on getting a hood to sit right?
  2. badazz81z28
    14,183
    110
    Las Vegas, NV
    Start with the panel that doesn't move....the 1/4. Align the door to that and then the front fender to the door. Hood last.
    Btw don't expect oem panels to have perfect gaps
  3. jbloake
    jbloake Veteran Member
    247
    26
    May 1, 2002
    Yes make sure bushings are good indoor hinges and door is aligned first
  4. Twisted_Metal
    25,386
    327
    Post pics of how the hood fits.
    Also pics of where the door and fender meet the windshield pillars.
  5. Ferg1031
    Ferg1031 Member
    38
    May 2, 2016
    Portland, OR
    Cool. Will post pics tomorrow if I can. Doors meet the 1/4's fine. Fenders meet the doors fairly well. But I'll post pics for sure...
    Thanks!
  6. Ferg1031
    Ferg1031 Member
    38
    May 2, 2016
    Portland, OR
    Here's some pics of the drivers side.
  7. Twisted_Metal
    25,386
    327
    The rear, bottom of the fender needs to be pushed inward to match the door better.
    It might require a shim at the bottom to slightly flatten the fender curve if the center still sticks out when you get the top and bottom aligned with the door and rocker.
    If the fender gets inward of the door edge... Don't open or close the door!
    The fender and door are a tight fit, a smooth transition between the two is the BEST you can get without interference.
    (Factory allowed the fender to be outward of the door just a touch.)
    The door/quarter and fender/nose look good on the driver's side.
    I can't see the hood alignment to give you any assistance there.
  8. Ferg1031
    Ferg1031 Member
    38
    May 2, 2016
    Portland, OR
    Here's the hood and passenger side. Sorry about the delay, been busy.
  9. larrylarry
    larrylarry Veteran Member
    1,314
    41
    Dec 22, 2011
    San Antonio Tx
    Does the hood latch/lock into place? Looks to me that the bumper cover is just a hair to far to the left. Might have to move the radiator support a little bit.
  10. Twisted_Metal
    25,386
    327
    It's hard to tell from this pic but it looks as though the top/front of the door may be "in" a little too much.
    The top edge of the door and the "A" pillar should be a smooth transition.
    A closer pic of how those pieces align would help.
    Unfortunately... You need to move the fender out a bit to allow the door to move outward.
    The fender movement is what you're really after... It will allow you a little more gap between the hood and fender.
    A bump to the left on the radiator support might be needed.
