Has anyone ever seen this!
Discussion in 'Body Restoration' started by lacamaro, Feb 15, 2011.
  1. lacamaro
    lacamaro Member
    91
    Mar 24, 2010
    New Mexico
    I peeled the car cover off the car last friday only to find this on the roof of my 73 Z28... I know it was painted last year before I bought it, not the best paint job, resell red I suppose. This is the only place it "fractured" for lack of a better word. It did get down to -15 below zero..... anyone seen this before?
  2. BigBlock73
    2,012
    56
    Jul 10, 2002
    Accord,New York
    WOW that is bad
    -15 in New Mexico
  3. lacamaro
    lacamaro Member
    91
    Mar 24, 2010
    New Mexico
    YUP! ~7500' elevation
  4. Twisted_Metal
    26,804
    867
    Oh for f00k sake..... I've never seen anything like that. :eek: :eek:
    Removal doesn't look to be an issue. :screwup:
  5. 4buckeyes
    4buckeyes Member
    30
    Feb 6, 2010
    columbus,ohio
    Paint Peel
    It almost looks as if the paint never adhered to the surface due to the lack of preparation.:screwup:
  6. lacamaro
    lacamaro Member
    91
    Mar 24, 2010
    New Mexico
  7. 4buckeyes
    4buckeyes Member
    30
    Feb 6, 2010
    columbus,ohio
    How do you post a new thread? I am still new to this newer technology.:confused:
  8. lacamaro
    lacamaro Member
    91
    Mar 24, 2010
    New Mexico
    Exactly.... the car was painted red, before that seller said it was orange when he got it, I see yellow below that and then primer.... weirdest thing I have ever seen!! Not the whole roof, about a 2'x2' section......
  9. Somiechev
    Somiechev New Member
    May 16, 2010
    Victoria, Australia
    I feel for you. Here in Australia I've seen similar damage due to excessive heat. None quite as bad as yours. Rapid or excessive temperature change and poor preparation before painting combine to cause the damage. I had a windscreen shatter for the same reason.
    The metal and its coating will contract or expand at different rates -particularly if the skim coat is as generous as it looks in the picture and if it hasn't bonded correctly with the metal - could be it wasn't dried well enough before skim coat or done on a day of high humidity.
    Take it to your local body shop - you may get away with just redoing the roof. Find a warmer spot to keep your invetsment safe.
  10. MrRedfish
    MrRedfish Veteran Member
    205
    Aug 30, 2010
    Bastrop, Texas
    wow that sucks
