Head Gaskets
Discussion in 'Engine Topic' started by dcozzi, Oct 14, 2019.
  1. dcozzi
    dcozzi Veteran Member
    3,080
    413
    May 1, 2002
    Phoenix, AZ
    I had to read it a few times but, I fully understand the relationship now. Thanks for the detailed explanation.
    The exhaust is already lifting slightly at the base of the intake and the intake is lifting slightly at the base of the exhaust. Hence the term "overlap".
    Once again, a great explanation of how the "brain" of the engine works.
  2. dcozzi
    3,080
    413
    May 1, 2002
    Phoenix, AZ
    I would never use an impact on rocker nuts. Sounds like a good way to fracture them. Impacts are for wheel lugs and frame mounted bolts not your valve train. I like to have a "feel" when I am making any adjustment of parts that have a moving relationship. That's only my point of view though. I am no expert. Last time I did valve lash the motor was being built on a stand and was 10 years ago.
    I remember the "spin the push rod until it feels some resistance" method from way back when. I think it was in David Vizards Rebuilding Your Small Block Chevy book.
    Before we knew better about proper adjustment, we would run the valvetrain "loose". Looking back, we did not really know where the lash was. Sometimes get only part of the cam's lift and/or bend pushrods at higher RPMs. Real shadetree stuff back then. Hell, we were kids.
  3. dcozzi
    3,080
    413
    May 1, 2002
    Phoenix, AZ
    Super Shops used to be cool. Now, they act like you are bothering them by shopping there. Still the only game in town for speed parts unless you want to drive to Mesa to Loper's.
  4. Knuckle Dragger
    14,869
    1,369
    Nov 2, 2002
    Waddell AZ
    Maybe for the novice, it's all about knowing how to use your tool........... :)
  5. G72Zed
    G72Zed Veteran Member
    1,193
    275
    Sep 8, 2015
    If you ever see the "hot rod" mechanic/tuner take out an air ratchet or impact to adjust or back off your valves, my advice would be "Run Forest Run" LOL.
  6. G72Zed
    1,193
    275
    Sep 8, 2015
    Your welcome dcozzi. I was worried perhaps my explanation was not clear enough or to complicated, or well phrased.
    The other thing I would (& do) look into if it's a Hyd lifter is the manufactures preferred plunger "preload" after zero lash if they have anything on this.
    EX: If using a 3/8 stud, @ 24 TPI, a 1/2 turn would be .021, and 3/4 turn is .0315 preload
    A 7/16 stud @ 20 TPI is .050 per turn, so easy to figure out preload math on that one.
  7. Knuckle Dragger
    14,869
    1,369
    Nov 2, 2002
    Waddell AZ
    Maybe I missed it but I don't see where anyone said anything about adjusting them with an impact.
  8. Lars_2Gen
    Lars_2Gen Veteran Member
    625
    146
    Dec 29, 2017
    Fullerton, CA
    I remember super shops! I spent too much money there back in the early 90s. They closed out here long ago. Didn't realize they were still around.
  9. djorgensen3
    djorgensen3 Veteran Member
    485
    51
    Oct 15, 2009
    Peoria, Az
    They aren't open here either. Been closed for a really long time...20+ years. If there is one still here, its news to me...
  10. dcozzi
    3,080
    413
    May 1, 2002
    Phoenix, AZ
    Youre right! I am thinking of the Lopers on Indian School Rd. Super Shops has been gone a long time. I obviously haven't used a speed shop for anything for a long time.
