Head Selection Help for 383
Discussion in 'High Performance Modifications' started by Lewspike69, Nov 24, 2012.
  1. Lewspike69
    Lewspike69 New Member
    Nov 24, 2012
    CT
    Hello,
    New to this site. Had to join because of all the knowlegeble members.
    Over the past year, I have been building a 383 for my camaro. I am doing this entire project myself under the council of my local engine builder. So far I have the shortblock completed. Now moving my way up to the top end, I picked out the XR282HR cam with the required retrofit roller lifters.
    I just can't seem to decide on cylinder heads. I want to go with the AFR 195 street heads, but I hear and read otherwise. One reason being the valve springs wont be compatiable with my cam (I know I can buy additionally the right set). And most commonly that I can get just as good as a product for less money with another head.
    My engine builder wants me to go with Edebrock performer heads. He says there great heads out of the box and they will come with the valve springs too. I think hes biased because there the heads on his foxbody haha.
    I also have looked at Dart Pro Platnium heads, as well as others like brodix, profilers, trickflow, or the E-Tec line for Edlebrock
    Im planning on using an edlebrock performer intake and either a Holley or AED 750 cfm carb. Maybe 650 cfm
    Also the purpose of this car is to be an every other day/ maybe weekend thrill ride. I want it to be wild but retain essential street manners. Something like fuel economy is not important but would be nice to get decent mpg when driving easy. I guess you can say the tier in between daily driver and street machine, closer to the street machine lol
    The heads I need to buy need to be aluminum, around 64-65cc for my compression (around 9 and 3/4 :1), have im thinking 195cc-210cc intake runners, and work well with my cam.
    Please help me decide on the best head for my combo. I really want to spend my money wisely. Feel free to ask any other needed info.
  2. 77nomad
    77nomad Veteran Member
    2,123
    Nov 20, 2009
    Ski Town
    This is my opinion and merely my little own opinion. But I almost never see Eddy's on a serious street motor. So Can I say there bad, not really. I see AFR's on every combo under the sun and all of them make serious power. I have never owned either. I have Canfields. Slightly lower flow numbers than the old AFR's but the were $500 cheaper at the time. So I erred on the side of budget. Now that Canfield is gone and mine are on their last legs, AFR will get my money the next go round.
  3. 4wheeler
    4wheeler Member
    69
    Nov 6, 2007
    South Jersey
    Look at my post two post above yours. I'm looking for heads like you are with alitte help. I'm picking the JEGS heads .. they are on sale now and I'm told they are Prrofilers with JEG stamped on them. The price is right.
    4wheeler
  4. 70ZED
    70ZED Veteran Member Gold Member
    353
    31
    Jun 21, 2010
    Calgary, Alberta Canada
    Mine has AFR 195's. I really like the power, feels like a big block torque wise
  5. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    Heads are where the power is made. Buy the best you can afford that fits your budget.
    I've used a few sets of AFRs myself and they make serious power on everything I've thrown them on. Quite possibly the best out-of-the-box heads you can buy. And you can buy their assembled heads with springs that are compatible with a hydro-roller cam. They cost a little more but they're worth it in my book. I keep using mine over and over on different combos.
  6. soco200p
    soco200p Veteran Member
    374
    Feb 22, 2004
    Chicago burbs', Illinois
    It really comes down to what you want to spend. If you want the best of the best, then AFR is the way to go, but they also carry a price tag to refelect being the best.
    I also wouldn't pick out a head simply for the fact it might have the right springs you need for your cam. Virtually ever cam from ever manufacture calls for it's own specific spring and it would be hard if not impossible to find a head that has the exact springs your cam needs. I would simply factor in another $80-$100 on whatever heads you get to buy the correct springs your cam calls for.
  7. Lewspike69
    Nov 24, 2012
    CT
    Do you think the valve springs that come with the AFRs will be compatable with my cam? say specificly the 1040 castings.
    Ive read otherwise to what my engine guy told me
    thanks for the responses
    and about to look at other thread
  8. Rascal
    Rascal Veteran Member
    259
    Apr 18, 2002
    Severna Park, MD
    Dart Pro 1
    AFR's if $$$ is no option; I went with Dart Pro 1's bare and probably saved $500 over AFR's. AFR's are great heads but they have out priced themselves. I used Dart Valves +.100 and Dart spring locators, then all Comp Cams components to exactly match my cam. Including valve springs, retainers, locks, valve seals, rockers, pushrods, and lifters. I cleaned up the bare castings myself of any bumps and seams in the runners (intake & exhaust). I port matched the heads to my intake manifold. I also de-burred the spark plug holes in the combustion chambers. My machinist assembled them for $150, checked all clearances, lapped all the valves, verified every spring pressure and insured correct installed height of all springs (ESSENTIAL).
    Dart Pro 1: 2.02in/1.60ex, 200cc runners, 64cc chambers, Angle Plug
    $900 Bare Heads
    $600 Parts and labor (Assembled; valves, springs, retainers, locks, locators, seals, & labor) ready to bolt on
    $1500
  9. theflash
    11,039
    33
    Feb 27, 2004
    Podunk, CT
    Welcome to the site neighbor
  10. Damon
    12,939
    21
    Nov 16, 2000
    Philly area
    AFR has several spring packages available for their heads (almost all manufacturers do). You can call and ask them about changes/upgrades to the spring package your heads come installed with.
