HEADERS for a LS motor in a 75 and up 2nd gen
Discussion in 'High Tech Retrofits' started by jazzdriver, Jan 22, 2011.
  1. jazzdriver
    jazzdriver Member
    41
    Oct 31, 2010
    westcoast
    I have been perusing the threads and all the info on headers etc. Lots of the posts are a couple years old now and would just like to get some current info it we could.
    Have a 77 trans am with a newly positioned ( YAAY ) LS2 with T56. Headers have moved up to the top if the "to do " list.
    My motor is not the setback 1 inch but am using the adapter plates with the Original clamshells and the metal brackets from clamshell to motor.
    The pacesetters 70-2256.. Do they fit..is it easy to cut off the collector sleeve and reweld it.. $300 leaves some room for a weld shop to do some work
    Edelbrocks 65073 about 6hun I think. Look good but apperently for the 1 inch setback plates.. ARE WE HAVING GOOD FIT OUT THERE WITH THEM. I look of them cause there is bolt on collecters at the bottom
    There is Stainless sets for 98-2002 camaro's on ebay for just under 2 hun and they look good. ANYBODY TRIED THEM???
    http://cgi.ebay.com/ebaymotors/98-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Also I am not up to speed on these slip in ends of the pace setters..Is it a weld on and be done with it...Used to the old collectors from the 70's the bolt on type wich I kinda like if they or the engine etc etc has to come apart??
    Ill pay the bucks if they work fine but if I can save a few hundred I can deal with a little tweak and grind........
    Thanks In advance
    Appreciate it
  2. Pump Guy
    Pump Guy New Member
    13
    Apr 2, 2009
    Edmonton, Alberta Canada
    I used the edelbrock headers / mount plates for the 4LQ install; fit and finish has been fantastic. As I am using a 4L80, there were a few zip disk mods required to the the dog house and converter cover, but so far so good..
    Would highly recommend their kit.
  3. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    935
    Oct 22, 2005
    Niceville, Florida
    I got Dynatech's (see link below) and am using them with the Edelbrock adapter plates. Fits great, nice looking ceramic coating, very complete kit includes nice tapered collector reducers, O2 bungs and plugs for same, bolts, gaskets, etc. Only issue was that the O2 sensor is on top of the collector and with the set-back would hit the floor on the driver's side, so I put a plug in that one and welded a new bung in the collector reducer. And...I had to run my steering shaft around the left header, but I doubt that would be an issue with OE steering. I paid $391 shipped, but I see they have come down to $378--I think a bargain. I have read that the Edelbrocks have a problem with the coating coming off easily...don't know if they have that resolved.
    http://www.autopartsdealer.com/Dynatech%20178%20LSX%207081%20CAMARO%20H_115_90940025c-p1859274-p.html
  4. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I wouldn't mind seeing a nice stainless steel set of headers w/o some crummy coating that actually works, unless that is not possible. Even the stainless Eddys have a coating on them that has mixed reviews, unless that has been improved.
  5. JAMMINJ007
    JAMMINJ007 Veteran Member
    397
    Dec 27, 2005
    Houston, Tx
    Nope Eddy's coating suck! Otherwise the headers fit and function is great!
  6. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    that stinks. so is there a header that fits well and doesn't have the crappy coating issues? Seems like you can get one or the other but not both, at least for full length headers.
  7. banaro79
    banaro79 Veteran Member
    268
    Dec 27, 2010
    hamilton, new jersey
    i dont know if this helps but i have the heddman headers they come coated and very well made check my thread i have many pics. im not sure of the 1in setback since i used a brp kit but there seems to be a lot of room.
    http://www.nastyz28.com/forum/showthread.php?t=202786
  8. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    I have the edelbrocks too. The coating does suck but otherwise I like them alot.
    I made my own mounts that moved my motor even further back, I had to make a little bit of clearance on the pass side frame rail, but other than that they cleared everything well.
  9. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Scott from Hamilton, NJ
    what is the issue with edelbrock coating? doe sit peel or something?
  10. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    They look nice...wonder what they'll look like in a year;)
