Headers
Discussion in 'High Performance Modifications' started by Reed I, Dec 30, 2018.
Will full length headers hit with drop spindles 434 sbc 70 Camaro thanks for your help
  1. Yes
    0 vote(s)
    0.0%
  2. No
    2 vote(s)
    100.0%
  1. Reed I
    Reed I New Member
    Jun 29, 2018
    Will full length headers hit on 434 sbc on a ‘70 Camaro?
  2. DB Z28
    DB Z28 Veteran Member
    553
    39
    Nov 30, 2003
    Fond Du Lac
    no
  3. Billd5string
    Billd5string New Member
    Nov 24, 2018
    Las Vegas, NV
    Frankly, that would depend on the headers. The full length headers on my 81 are nice and high and have plenty of clearance. I agree with DB Z28, I doubt any headers from a reputable company would hit.
  4. GoldenOne7710
    4,610
    324
    Jun 23, 2004
    Athens, GA
    I have Hedman full length headers on my Camaro...and it is lowered with coil springs a solid 2" in the front. They hug the floorboards very well. The collectors are hardly any lower than the subframe.
  5. BonzoHansen
    19,131
    618
    Jun 1, 2005
    Scott from Hamilton, NJ
    My American racing headers don't hit anything and my car is lowered.
  6. CorkyE
    10,010
    356
    I'm using Hedman 65104, they're full length, 1 3/4" primaries. It's a tight fit all the way around but they do fit. I also have lowering springs on the front. Make sure your body bushings are in good shape. If not, now is a good time to replace with solids.
  7. Lowend
    14,819
    376
    Mar 25, 1999
    San Jose, CA, USA
    Any full-length header is going to drop your ground clearance to some degree.
    You really need to be more specific if you want accurate answers
    (and I fixed your survey)
  8. turbobuick
    turbobuick Member
    65
    16
    Nov 24, 2018
    Bonzo,did your full
    Length headers interfere with the T-56 slave cylinder? Where are you located? I’d love to check your car out at some point. I’m in Denville.
  9. BonzoHansen
    19,131
    618
    Jun 1, 2005
    I am running a mechanical clutch, no hydraulics.
  10. 1978 Z/28
    1978 Z/28 Member Gold Member
    83
    15
    Jul 17, 2017
    New Brunswick
    I have hooker 2117-1HKR no clearance issues
