Hedman and Pypes
Discussion in 'High Performance Modifications' started by Z71Dav, Apr 18, 2014.
  1. Z71Dav
    Z71Dav Member
    40
    Feb 24, 2012
    NL, Canada
  2. krabben1
    8,185
    51
    May 16, 2007
    ( . Y . )Delco
    Both systems are good.I run the hedmans with the pypes system with the transverse muffler on a bb.Quiet while idling,louder as you go into the pedal.
  3. Z28zz383
    Z28zz383 Veteran Member
    811
    11
    May 11, 2012
    Florida
    That will be a nice system....Call hedman or summit to verify the fast burn heads are going to match up with the header tubes. I believe they will be since they are 1.75 dia. Fast burns have a higher exh. port.
  4. JWZ28
    JWZ28 Veteran Member
    1,237
    Feb 27, 2011
    Alabama
    As far as mufflers go I love my Pypes Race Pros. Good rumble at idle, no drone at cruise, and scream when you mash the loud pedal.
  5. doublec
    doublec Veteran Member
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I have Hedman 65104s and the Pypes Race Pros..love em.
  6. toddoky
    toddoky Veteran Member
    227
    Mar 5, 2013
    Bowling Green, KY
    Although the ZZ4 heads are a D-port design, they are not the Fastburn heads. All the GM D-port heads(LT1, LT4 and ZZ4) are raised .100" with the exception of the Fastburn heads, which are raised .200".
    The Hedman headers (and most other mass produced headers) are designed primarily for "stock port" heads (i.e. non-D-port), so even though they will definitely bolt-up and probably not leak, the possibility of shrouding at the roof of the port will exist. If that is important to you, you can create a port trace template and overlay it across the header flange to determine the amount of shrouding that will be present if any.
  7. krabben1
    8,185
    51
    May 16, 2007
    ( . Y . )Delco
    Do you work for GM at the corvette plant?
  8. toddoky
    227
    Mar 5, 2013
    Bowling Green, KY
    No krabben1 I don't work for GM. I work at Holley here in Bowling Green.
  9. krabben1
    8,185
    51
    May 16, 2007
    ( . Y . )Delco
    Damn.There goes my in for a new vette,lol.
  10. Z71Dav
    Z71Dav Member
    40
    Feb 24, 2012
    NL, Canada
    Any recommendations for the D-port heads ? There doesn't seem to be too much there that will fit the 81 Z28 and D-port. Ive searched and was told the Hedmans I listed will work fine.
