HEI upgrade options - street car 350
Discussion in 'Engine Topic' started by fstarocka, Oct 1, 2019.
  1. fstarocka
    fstarocka Member
    37
    Feb 1, 2013
    Seattle
    Hi all.. i got a 77 with a vortec 350 9:1 qjet roller GM hotcam, 16gb of ram, 3k stall, headers, intake, L31 heads - etc etc - drives gr8 but seems to float when I mash it - im planning a 383 blower build later on but wondering if the MSD 6A would help me along in the spark division - wanna do it on the cheap.. and what else do i need if i get a control box? the MSD coil too? or is the HEI in cap one ok - or can I just upgrade the HEI module? This is a street toy -
    sorry for the questions but about the last thing to upgrade on my ride is the ignition
  2. larrylarry
    larrylarry Veteran Member
    1,544
    70
    Dec 22, 2011
    San Antonio Tx
    I don’t think a MSD 6A would be much help on your present motor, on a blower motor yes it would help. I have 3 different kinds of HEI coils, hi performance to stock. I can’t tell the difference between them. Ign. module, if it’s working just leave it alone, after a lot of research I’ve done on modules you won’t see any gain in HP. Your float or hesitation problem is a carburetor problem I bet! I’m not well versed on Qjets. You won’t need anything else except for some better spark plug wires if you get a new spark box, they come with everything needed. If you do get a spark box use a resettable 3 amp fuse on the 12volt power wire that way you won’t burn it up like I did.
  3. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
  4. Zspoiler
    Zspoiler Veteran Member
    3,213
    252
    May 6, 2012
    Federal Way, Washington
    I have a 1979 Z-28 with a supercharged 377 cubic inc small block with all the "toys". I a DUI ignition coil and a Crane HI-6 TR ignition box .with MSD 8MM ignition wires .All which are not cheap. You can check on an MSD type set up as well. And or check the swap meets and such.But that mean it works. I took my time to save my money to get mine . Just to
  5. fstarocka
    fstarocka Member
    37
    Feb 1, 2013
    Seattle
    reason im asking is because ive read the hEI kinda falls off around 4-4.5k - thats what ive "read" -not experienced.. the 6a units are found cheap so was wondering - im trying to eliminate possible issues one at a time.
    Can someone explain what valve float feels like? When i mash it from say 10-15mph.. it takes off but soon after it kinda starts floating, like the trans jumped into neutral (im talking pedal to the floor / WOT) with a 3k stall.. the carb seems to run well - i get 23mpg highway and it has some nice power but the top end issue is odd..
    when i put in the hotcam i matched a set of single street springs, i didnt want to go dual springs cos the hotcam isnt THAT crazy on the ramps etc - or am i wrong? i used the comp tool and my micrometer to cut down the guide bosses almost equal..
    Very informative articel here:
    https://www.chevelles.com/forums/10-1999/2995-msd-vs-stock-hei-2.html
  6. larrylarry
    1,544
    70
    Dec 22, 2011
    San Antonio Tx
    Valve float is caused by weak/worn out valve springs. Don’t get fixated like I do sometimes by thinking it’s valve float when it’s really something else. Your transmission may be shifting slowly. Check the transmission module, it has a vacuum line going to it, see if it’s leaking. Put a shift kit in it. I did that to my TH350 an it really woke it up! Readjust the rocker arms but read up on how to do it correctly first. Recheck your timing. 80% of the time it’s something simple.
    HEI’s do kind of poop out above 5 grand but how much do you push it to 5 grand? I hardly ever get up to 5500 rpm’s but I don’t drag race either.
  7. ls777z
    ls777z Veteran Member
    2,143
    12
    Feb 19, 2000
    Clay,NY
    What is your tach doing when you experience this "floating"? Staying steady at the rpm? Climbing?
  8. 450bench
    450bench Veteran Member
    3,091
    31
    Feb 25, 2002
    memphis, tn-shelby
    I'm running a bone stock GM Delco Remy HEI in my big block car. I changed one stock spring to a lighter one. Car revs all day to 6500. Tough to beat the old stock GM hei.
    I've got the cheap eBay Chinese $50 hei on the shelf as well. Never had an issue with them either.
  9. biker
    biker Veteran Member
    822
    65
    Dec 7, 2014
    New Liskeard Ontario Canada
    HEI works so well if it isn't worn out. I have a DUI unit, second one in 25 years. Easy 7000 rpm, great customer service when u need to modify or recurve. Expensive but worth it. A good stock one curved properly with a hot coil works well too.
    Are you starving for air or fuel at high RPM? When I upgraded my engine, I couldn't rev above 5000 at wide open with the stock short air filter.
    G72Zed likes this.
  10. 1980RS
    1980RS Veteran Member
    3,222
    532
    Jun 17, 2006
    MN
    Best thing ever made for an HEI is a MSD 6AL, just make sure you put a low resistance button under the coil or it will burn through the rotor. Mine did. Make sure you get a good coil as it will help a lot. I can spin my HEI to 7K but my distributor now needs to be replaced as it has too much shaft side clearance.
    G72Zed likes this.
