HELP HEAD IDENTIFYING
Discussion in 'Troubleshooting & Diagnosis' started by Tylermayhem, Nov 28, 2019.
  1. Tylermayhem
    Tylermayhem New Member
    Nov 28, 2019
    Can anyone please tell me what heads these are? Was told they are a set of Mike Chapman heads??? Came with the motor. Motor was in a crate and was told dyno time only after build. Everything appears to be true to what the owner said. I can’t for the life of me figure out what heads these are???? Only things I can find anywhere on them is on front there is a stamp that says “trick head work” followed by the numbers 477277. On the rear corner there is a 3 stamped and on the exhaust side only thing stamped is a 619. upload_2019-11-28_14-5-18.jpeg
    buick skylark likes this.
  2. bourbon_scotch
    2,402
    143
    Jan 10, 2003
    USA
