Help me pick a stereo for my work truck
Discussion in 'The BS Topic' started by OsborneConst, Nov 22, 2015.
  1. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I am looking at finally replacing the stereo in my work truck. I haven't bought an aftermarket stereo in probably 15 years. I used to be very up to date on car audio, but a lot has changed in the last 15 years! I am wanting a stereo that at minimum has bluetooth so I can listen to my iphone while plowing, and do phone calls through the stereo as well. I would also like to be able to use a wired back up camera and get rid of my wireless one. I also need something with an am/fm tuner. (my buddy bought one that only worked with a phone, no tuner on accident)
    The truck is 2003 crew cab 2500HD. I have replaced all 4 speakers with Polk Audio higher end speakers. It does not have Bose or On-star, but does have steering wheel controls.
    Must have:
    am/fm
    bluetooth
    backup camera capabilities
    Want to have:
    steering wheel controls to work
    Would be nice to have, but not necessary:
    Be able to play streaming video from iphone
    GPS
    Any other suggestions???
    Thanks for all input!
  2. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    The 03 will require a $50-$150 wiring harness adapter ( depends if its a base model, Onstar, BOSe etc)
    NOW Go look at stereos
    Wattage is all the same they have plenty for most/
    Look for a name brand, with Pioneer, JVC, Alpine, Kenwood etc all having Bluetooth, USB, ipod jack etc Go look. If you have wheel controls now, they make interfaces for those too.
  3. GoldenOne7710
    4,766
    377
    Jun 23, 2004
    Athens, GA
    I'm partial to Pioneer. I've installed their head units in the last 3 daily drivers I've had. I like them because they're (IMO) one of the most user friendly units out there. Not to mention the tuning options to get a better quality sound vs the rest I've had experience with. Pair it with some replacement Pioneer door/component speakers and you'll have a nice sounding stereo that would 'usually' blow the factory system away.
  4. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I have always been a fan of pioneer. My problem is, I started looking online and got overwhelmed by what is out there.
  5. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    DON'T GET A SONY! obnoxious beeping noise to remind you to remove the faceplate every time you shut the car off.:rolleyes:
    Get one that's easy to handle - not push button volume or tiny knobs, etc.
  6. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    I just installed a touch screen nav Pioneer into a 2012 Silverado. I installed the backup camera and all the bells and whistles. It took two interfaces to use the steering wheel controls and the factory XM antenna. Programming was a little time consuming but overall a great setup.
  7. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    All of my pioneers have done that too, but it can be disabled.
  8. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    What model did you get?
  9. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    There is an up to $100 mail-in rebate on the Pioneer AVIC-5100 thru 8100 series and the SPH-DA120
  10. krabben1
    8,159
    44
    May 16, 2007
    ( . Y . )Delco
    I have two newer radios.
    I find it very hard to get good regular sound out of them with all the "sound" options they have programmed in.
    I got the one in the chevelle sounding good finally,then disconnected the battery and Im back at square one.
    I wish they had a simpler radio out there,like the old days.
