Help with engine belts
Discussion in 'Engine Topic' started by ISRcamaro, Oct 6, 2019.
  1. ISRcamaro
    ISRcamaro Veteran Member
    564
    23
    Oct 10, 2016
    Israel
    Hi
    I might get it wrong but at the manual seems there's a 4th pully I don't have on my engine.
    What it is? At the drawing, it doesn't look like the power steering pump...
    And with the side draw (on the left corner) with the 3 pullies it says LG4 engine which is 305 but mine is 350.
    Anyway, I'm looking for new belts. I have 80 Z28 but the engine number is 3956618 which I understood it's from 69' area.
    Can anyone help with the right parts?
  2. GoldenOne7710
    4,766
    377
    Jun 23, 2004
    Athens, GA
    If you're asking about the accessory that's below the alternator on the far passenger side of the engine, that would be the smog pump. A LOT of people leave them off when they replace an engine.
  3. ISRcamaro
    564
    23
    Oct 10, 2016
    Israel
    I don't think i have it. Never saw it. Ever.
    Any idea for the right belts?
  4. Twisted_Metal
    26,944
    925
    The alternator, water pump and crank pulley will be in exactly the same place on a 305 or 350.
    I used a bracket set from a 305 on my 350.(no smog pump)
    That number on my alternator belt is: 45013 10A1145.
    (Not sure of the brand.)
  5. ISRcamaro
    564
    23
    Oct 10, 2016
    Israel
  6. Gary S
    22,410
    752
    There are quite a few differences. Some cars had Air Conditioning and some didn't. Some cars had smog pumps and some didn't. Some cars had power steering and some didn't. There were also two different belt layouts over the years for the water pump. Some have only a single belt running them, and some have more.
    The belts you need will depend on what accessories the engine has and the layout of the belts across the accessories.
  7. ISRcamaro
    564
    23
    Oct 10, 2016
    Israel
    I know there is no A/C or smog pump but I don't know what exact engine to I have.
  8. tom3
    tom3 Veteran Member
    11,917
    327
    Aug 1, 1999
    ohio
    Post a picture of the front of your engine, should clear it up pretty easily.
  9. Gary S
    22,410
    752
    The engine shouldn't matter. What will matter is the accessories on the engine and the available pulleys for putting belts on.
  10. ISRcamaro
    564
    23
    Oct 10, 2016
    Israel
    I don't know how you'll figure it by pictures but those are the best I found.
    I don't know if the pulleys are stock or not but I just saw A LOT of different types at Summit Racing by length and width.
