hidden vin numbers.
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by dutch73camaro, Jun 10, 2018.
  1. dutch73camaro
    dutch73camaro Veteran Member
    162
    34
    Jan 7, 2016
    Beverwijk, Netherlands
    hi,
    are there more places for hidden vin numers on a 73 camaro then on the firewall ?
    i also read alot that is not the same number as the vin, but only a body number ?
    still need to check the numbers papers are not here at the moment.
    i see also a number in my left inner wheelhouse but that is another number.
  2. budro6968
    budro6968 Veteran Member
    3,129
    487
    Apr 2, 2016
    Jax Florida
    It will be a partial VIN. The year The place built L or N and the last series is the sequence off the line.
  3. dutch73camaro
    162
    34
    Jan 7, 2016
    so that should match your last digits of the vin correct ?
  4. budro6968
    3,129
    487
    Apr 2, 2016
    Jax Florida
    Yes. The trim tag does not match though. I have heard that the other places are on the sub frame rail also but have not looked my-self to verify. I'm sure there is info on this site about where others may be. The stamp pad on the engine block in front of pass head and the transmission if original will have a pad as well. Just have to look for it. Hope someone will chime in to give more info. There are folks here that are walking encyclopedia's
  5. 70lt1z28
    70lt1z28 Veteran Member
    3,254
    634
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Nothing VIN on a subframe, at least not on a 70. Maybe by 73, but I doubt it. There is a date code on the sub directly under the drivers door facing to the outside of the car. By the back subframe bolt.
