Hillbilly's Rented Mule
Discussion in 'Project Progress' started by hillbilly75, Dec 29, 2013.
  1. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Man. Dedication. Keep up the work.
  2. hillbilly75
    hillbilly75 Veteran Member
    417
    Jan 7, 2011
    Nowheresville
    Thanks! I finished up welding the back edge of the trunk floor where I went a little too deep with the spot weld cutter. My tail panel should be here by tomorrow so hopefully I can get that mocked up and see how it fits. I can't put it in until I fix a couple of spots on the passenger frame rail.
  3. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    looking nice, keep it up!
  4. hillbilly75
    417
    Jan 7, 2011
    Nowheresville
    Thanks man!!
    I got the tail panel the other day, so I mocked it up with the inner tail panel and the quarter to see how everything fit.
  5. hillbilly75
    417
    Jan 7, 2011
    Nowheresville
    You can see I'm missing the filler piece that attaches to the tail panel and the quarter. The filler pieces are pretty mangled, I'm taking the best parts of both and try to recreate each one. If I fail I'll see if I can find some used ones.
  6. perkalator
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Its looking good. Its metal you can always add.
  7. jester0618
    jester0618 Veteran Member
    271
    26
    Dec 6, 2015
    Bryan, OH
    Looking real good. Wish it wasn't so danged cold here, I might actually get some work done.
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    Would it make sense to get a piece from a donor?
  9. hillbilly75
    417
    Jan 7, 2011
    Nowheresville
    Yeah it would but I'm using a 2 pronged approach to this though. I'm making some and looking for a pair at the same time.
  10. hillbilly75
    417
    Jan 7, 2011
    Nowheresville
    Time to update this thread a little.... when I pulled the tailpanel off I knew I needed to replace the last 3" of the framerail and bumper mount. I cut the rotten pieces out and I had good solid metal so I made up a new end piece and got it burned in.
