Hillbilly's Rented Mule
Discussion in 'Project Progress' started by hillbilly75, Dec 29, 2013.
  1. hillbilly75
    hillbilly75 Veteran Member
    415
    Jan 7, 2011
    Nowheresville
    They will soon actually I had to sift through and organize the pics to get an idea of what went where. I use an at home server now and it’s taking some time to get this done.
  2. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Success!!!! I finally got all of the photos fixed on the build thread.... and now for some updates:
    The tailpanel is fully welded in also I moved to the passenger frame rail. It had a lot of problems that needed to be addressed.
  3. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    First off I ordered up a frame rail for a 70-73 and cut out the section that I would need.
    Then I cut out the bad section and prepped the area to have the new piece installed.
    If you look close I added tabs to help gusset the frame rail. The new piece has corresponding holes so I can plug weld the two together as well as butt weld them
    This is what I wound up with once I was finished.
  4. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Since the frame rail is now solid I can move onto replacing the torque box, I’ll take some pics tomorrow of the progress.
  5. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    I cut a section of the floor out to remove the torque box. I’ll be reusing the floor section after I fix 2 thin spots I found.
    I didn’t get a chance to get the torque box out yet. It’ll be another week or so before I can work on the car again.
  6. dave@ztech
    1,940
    260
    Mar 27, 2016
    NY
    Really nice work, will have to go through the entire thread, then ask you questions about what you thought about certain parts , again, really nice work!!
  7. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Thank you! No problem if you have any questions ask away I’d be happy to answer them.
  8. T12pm
    T12pm New Member
    Aug 12, 2018
    Took awhile to read all 17 pages, excellent work I did a few cj jeeps frame off when I was younger lots of work but very gratifying when done(think that was the word I wanted). I just joined here as I was looking for info on camaros, I am a mopar guy or was one, three weeks ago I won a 1975 type lt custom one of a kind build and am learning as much as I can on them. One question why don’t you use a small turbo heater in the garage when it’s cold. But then you get condensation if it gets to warm in there
    hillbilly75 likes this.
  9. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    I have a propane heater, it’s a wall mount. It takes the edge off of the cold, but the garage isn’t insulated so until I get that project complete I’m limited as to how much heat I can get in there.
    Thanks for the kind words, you’ve come to the right place for info. I did a lot of reading at first, especially build threads.
  10. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    I just got a chance to get some work done on the car yesterday before work. I managed to get the torque box mostly cut out of the car. I have to clean up the rest of the metal before I start fitting the new one. 8C38AC45-52A9-42AB-AA65-A46427C304C6.jpeg
    I’m hoping the torque box and new frame rail play nice together, I’ll know soon enough.
