Thanks for the compliments guys, it means a lot! RS1979 yeah I got the idea from here.... Just don't remember what thread. All it is, is a 4x4, a 2x4 and 2 metal caster wheels. Very simple cheap and easy!! The drawback to it is if you have to go over a lot of cracks or rough surfaces it tends to want to tear the dolly out from under it. But using some caution I can wheel it in and out of my garage and it turns on a dime!!!
Thanks 76_Type LT, I've looked through your thread for some info and it has helped considerably! I did get some work done on it today.... Small things since I had to head into work. One of which was the windshield, I had a 50/50 shot of getting it out in 1 piece....and failed, it cracked half way out. One less thing to store I guess.
Also I looked at my steering column and it seems the lower plate that bolts to the firewall is rotted through. Anyone know of they sell just the plates?
That's Dirtdobber78, I really like how it came out. Not a whole lot of pic worthy stuff going on but I did pick up some much needed parts. Plus I found the firewall plate for the steering column and a non ac kick panel for the passenger side of the car.
re: the steering column plate, I don't know of anyone who sells that, but I bet you could pick up a used column pretty cheap. You might be able to repair just the rusted area. So what's the story on the roof? Is your roof shot?
76 Type LT: I bought a junk column off of the same guy I bought the roof from. It has a good plate that I'll take off and use on my column. The guy had a couple of 55 gallon drums full of columns for me to pick from... LOL. As far as the roof goes there used to be a nifty sunroof in my car that I didnt want. So the plan is to re-skin my car with this used roof. Plus use some of the roof structure to patch hole that is cut in mine. It'll be a lot of work but I like the look of a solid roof better. I also have some work to do down in the cowl area so that'll be addressed at the same time.
Gotchya. There are some great threads on roof replacement in the Body forum. I know Tony (volsfan) did a roof replacement and posted pics in his project thread http://www.nastyz28.com/forum/showthread.php?t=271268
