Hillbilly's Rented Mule
Discussion in 'Project Progress' started by hillbilly75, Dec 29, 2013.
  1. Da-bigguy
    3,613
    111
    Jan 19, 2010
    Cypress, TX
    That is looking good!
  2. hillbilly75
    hillbilly75 Veteran Member
    415
    Jan 7, 2011
    Nowheresville
    Thanks! Finished up the fender patch and I think it turned out pretty well.
  3. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    While I had the welder out I patched the thin spots that the replacement roof had. There were two areas plus a couple of pinholes that looked questionable, so everything was taken care of at once.
  4. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Been so cold lately that I had to wait till Sunday to get a decent day in the garage. But I managed to finish up the patch for the sunroof.
    I also got the rest of the old skin off, it took some measuring to figure out where I wanted to make the cut for the replacement skin.
  5. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    I had already sanded and coated the under side of the roof skin with POR-15.
    This how I ended up, it's almost fitted but I just ran out of time.
  6. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Finally after a lot of trimming and stressing I got the fitment I wanted for the skin. It's nice working with GM sheet metal, just some hammer and dolly work along with a check of the window trim I'll be good to go to weld it in.
    If you look close the front window lip doesn't quite line up in the picture. That is because I had taken the skin back off to coat the structure underneath and just set it back on there with clamps.
  7. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Here is the roof structure all welded and coated ready to be covered up for the last time. I hope once I get a nice day out in the garage I never see this again.:D
    Here is a better shot of the window lip fitment:
  8. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    Since I can't just work on one thing at a time I ordered up backing plates for the S-10 rear disc conversion and installed them. Got get around to ordering the rest and get it put on.
  9. hillbilly75
    415
    Jan 7, 2011
    Nowheresville
    I also started drilling spotwelds for the cowl replacement. It's not in bad shape except for the ends so it's be easier to do the whole piece in one shot. Nothing pic worthy yet on that though.
  10. Coadster32
    1,505
    89
    Oct 2, 2013
    Milford,CT
    Killer work. Doing a great job. Hope all this work doesn't relate to a trailer queen. I'd like to see you smoke some tire in it!!
