Hissing sound after turning engine off
Discussion in 'High Tech Retrofits' started by 75Maro, May 5, 2019.
  1. 75Maro
    75Maro Veteran Member
    406
    17
    Mar 31, 2008
    Dallas,Tx
    hey guys as the title says, when I shut the engine off there is a hissing sound coming from the engine. I think it’s coming from the air cleaner. 5.3 with a small cam. Runs great no issues just not sure what this sound is. Thank for any help.
  2. badazz81z28
    16,135
    373
    Las Vegas, NV
    The radiator has a leak letting steam out? I can’t imagine a sound like that from the air cleaner, carb or FI?
  3. 75Maro
    406
    17
    Mar 31, 2008
    Dallas,Tx
    No coolant leaks, no fluid leaks at all for that matter. I will try and post a short video.
    Thanks
  4. Twisted_Metal
    26,629
    763
    Did you have the A/C running?
    My A/C does that as the high and low pressure sides of the system equalize through the orifice tube after the compressor turns off.
  5. Bandit723
    Bandit723 Veteran Member
    2,997
    435
    Oct 1, 2016
    Waupaca WI
    Vacuum leak from the brake booster maybe?
  6. 75Maro
    406
    17
    Mar 31, 2008
    Dallas,Tx
  7. 75Maro
    406
    17
    Mar 31, 2008
    Dallas,Tx
    possibly vacuum? only heard after shutting engine off for about 3-4 seconds.
  8. xten
    xten Veteran Member
    2,451
    1,239
    Sep 24, 2014
    Pittsburgh, Pa.
    Sure sounds like vacuum
  9. 75Maro
    406
    17
    Mar 31, 2008
    Dallas,Tx
    crankcase ventilation maybe? exaggerated sound due to the aftermarket intake tube and cone filter?
  10. supwicha
    supwicha Veteran Member
    181
    13
    Feb 23, 2014
    Victorville, CA
    Couple things come to mind. Bad check valve on your brake vacuum booster. Incorrect PCV system setup (block goes into a vacuum then vents after shut down due to vacuum source with no corresponding ventilation), IAC pintle opening during shutdown (if equipped), or TAC opening during shut down (may need a throttle relearn?). Defiantly sounds like a large amount of vacuum stored in the intake system returning to atmosphere. A short duration, usually .5 - 1 second is typical, this sounds extended. Is this a new motor? My worst prediction would be a leaking intake valve that is in the compression stroke during shut down that is passing by the valve under compression pressure, and venting into the intake.
