Hissing sound after turning engine off
Discussion in 'High Tech Retrofits' started by 75Maro, May 5, 2019.
  1. supwicha
    supwicha Veteran Member
    182
    14
    Feb 23, 2014
    Victorville, CA
    That appears to be the coolant hose for the TB heat, not vacuum.
  2. supwicha
    182
    14
    Feb 23, 2014
    Victorville, CA
    You photos show the brake booster vacuum circuit, not the PCV circuit from what I can see. I'm looking for a hose connection that goes from the intake to the PCV either at the valve cover or the other entry to the block. Do you have that?
  3. 75Maro
    75Maro Veteran Member
    427
    17
    Mar 31, 2008
    Dallas,Tx
    You are correct. I just googled ls1 PCV setup and realized I have the pass side valve cover connected to the intake (wrong). I need to reroute it to the TB nipple on the same side (pass side).
    The small red breather is connected to the driver side valve cover and there is no routing to the intake (wrong) I also see from a google search that this isn’t correct either. I need to reroute this to the intake.
  4. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    I will post updated pics in the morning thanks for your help so far guys.
  5. badazz81z28
    16,382
    406
    Las Vegas, NV
    5342F80D-16BA-42A0-89FD-451CAAC4AA42.png Yup, I think you’re creating vacuum in the PVC while it’s running and when you shut it off it releases. The the valve cover should be drawing in fresh air that’s metered. Ie valve cover hose connected to the throttle body. Where the crank case air exits (driver valve cover) connects to the intake manifold to be burned. Since your fuel injected, you shouldn’t have any unmetered air entering the engine. Get rid of the red filter and route that to the intake manifold. Don’t forget the check valve.
  6. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    This is great info.
    Thanks
    I can’t make out the words in the picture. What are the comments on the blue line.
  7. dave@ztech
    3,321
    686
    Mar 27, 2016
    NY
    one says clean side the other says dirty side
  8. badazz81z28
    16,382
    406
    Las Vegas, NV
    Green is clean fresh air from the TB, the blue is dirty coming out of the engine to enter the intake manifold to be burned. The check valve is so air can only be pulled into the intake and not out of it.
  9. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    Any suggestions on the check valve.
  10. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    86ED0DF7-5AD2-4D9D-8DD7-CCF3A8352496.jpeg 1D14DE05-CB47-4F7D-9318-22D7979BEED9.jpeg 04E98951-21D0-406A-863F-F05D2047F2CE.jpeg Update: the hissing sound now last about .5 second after shut off. Thanks for all the help. Only thing missing now is the check valve.
