Hissing sound after turning engine off
Discussion in 'High Tech Retrofits' started by 75Maro, May 5, 2019.
  1. badazz81z28
    16,285
    393
    Las Vegas, NV
    New video?
  2. badazz81z28
    16,285
    393
    Las Vegas, NV
    Any 3/8 hose valve from the part store should work fine
  3. 75Maro
    75Maro Veteran Member
    411
    17
    Mar 31, 2008
    Dallas,Tx
  4. supwicha
    supwicha Veteran Member
    182
    14
    Feb 23, 2014
    Victorville, CA
    Much better. I'm glad you asked this question. Running the crankcase in a constant state of high vacuum can cause several issues. It can cause seal failure, oil consumption, draw in external contaminants like water/moisture, as to a degree effects piston travel. Back in the day, hot rod motors were "vacuum balanced" for this reason.
    75Maro likes this.
  5. 75Maro
    411
    17
    Mar 31, 2008
    Dallas,Tx
    Big thanks to everyone who helped out on this. Hope I can pay it forward to someone else on here.
  6. dave@ztech
    3,250
    650
    Mar 27, 2016
    NY
    So, the check valve solved the problem?
  7. 75Maro
    411
    17
    Mar 31, 2008
    Dallas,Tx
    rerouting the PCV hoses correctly solved the problem
    dave@ztech likes this.
  8. badazz81z28
    16,285
    393
    Las Vegas, NV
  9. 75Maro
    411
    17
    Mar 31, 2008
    Dallas,Tx
  10. 75Maro
    411
    17
    Mar 31, 2008
    Dallas,Tx
    Update - while the original issue (sound after turning engine off) is fixed, now the car idles rough/erratic in park. As soon as it’s put in gear (reverse or drive) the idle picks up to normal and all is fine. Not sure if this is related to the PCV reroute but it started right after. Thanks for any input.
