Hissing sound after turning engine off
Discussion in 'High Tech Retrofits' started by 75Maro, May 5, 2019.
  1. badazz81z28
    16,593
    438
    Las Vegas, NV
    Is the engine stock? Did you get a tune with the best pvc routed the way it was? The problem may be is the car was tuned with a vacuum leak if nothing was on the throttle body. Now that all the leaks are fixed, it’s not running good? Is the idle correct in park?
  2. 75Maro
    75Maro Veteran Member
    427
    17
    Mar 31, 2008
    Dallas,Tx
    engine has a small cam in it. The PCM was tuned out of the vehicle and its just a "start up" tune. The idle is erratic in park or neutral and fine in reverse or drive. I disconnected the batt to see if PCM maybe needs to relearn idle/fuel trims without the vacuum leak?
  3. badazz81z28
    16,593
    438
    Las Vegas, NV
    I would double check all the coils and connections. Make sure everything is secure. If all is good, I would be looking at the tune. What trans?
  4. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    4L60E
  5. badazz81z28
    16,593
    438
    Las Vegas, NV
    How did it end up?
  6. 75Maro
    427
    17
    Mar 31, 2008
    Dallas,Tx
    Seems to be running fine IDK maybe just had a fart stuck
    dave@ztech likes this.
