Holley carb and engine not running quite right
Discussion in 'Engine Topic' started by Elfmaze, Aug 13, 2019.
  1. Elfmaze
    Elfmaze Veteran Member
    973
    May 23, 2002
    Pittsburgh PA
    Hey guys,
    Starting to tear into this one.
    Carb: Holley 3310-11
    block: early 70's 4 bolt 355ci
    Intake: performer EPS 2701
    Exhaust: shorty headers
    Dizzy: flame thrower HEI
    Cam : mild Crane cam (pending cam profile from previous owner)
    Trans : 200R4 built by Janis Transmissions in Akron OH
    So car is ripping through fuel, which is to be semi expected. But its also fairly slow only hitting 0-60 times of around 8-9 seconds. semi hard to start but with about 1/4 throttle can get it reliably started, Wreak of gas smell pulling it into the garage. Origionally thought it was the cars origional 305 so dismissed the performance but on realizing it is a 350 It should be doing better.
    Started looking into the carb floats are set right but fuel pressure is a bit high at 8-5 or so. vaccum is reading only about 11-13 in at idle. mixture screws did not seem to have much effect. whats my next move here?
  2. muscl car
    21,741
    659
    Jul 8, 2001
    High Desert of Hesperia Calif
    Lower fuel pressure to 5.5lbs then check power valves to make sure they're not blown
  3. 77 cruiser
    77 cruiser Veteran Member
    542
    25
    Nov 17, 2006
    Frostbite Falls MN
    Vacuum leaks, power valve blown
  4. Elfmaze
    973
    May 23, 2002
    Pittsburgh PA
    So get an inline regulator, and if the power valve is blown it would leak fuel through at all manifold press leading to the overly rich?
  5. Elfmaze
    973
    May 23, 2002
    Pittsburgh PA
    I don't know where vac leak could happen... only has the power brakes on vac lines. the diagnostic port is capped and the other goes to the dizzy
  6. Elfmaze
    973
    May 23, 2002
    Pittsburgh PA
    I did Holleys procedure at the end of the video. I CAN kill the engine with the mixture screws, video says the power valve is "not" blown per that rubric.
    2:40
  7. CorkyE
    10,402
    484
    You would be amazed where vacuum leaks can occur. I use an unlit propane torch to check for vacuum leaks, intake manifold gaskets are pretty common leak points.
  8. Elfmaze
    973
    May 23, 2002
    Pittsburgh PA
    Ok, should be pretty easy for my to rig up a smoke machine and push some smoke back into the vac line, a glove over the carbs intake barrels should give the pressure I need right?
  9. jeff swisher
    jeff swisher Veteran Member
    1,381
    417
    Apr 26, 2018
    Yukon Oklahoma
    look down the carb at idle ..it should not be dribbling any fuel at idle from the boosters.
    Timing curve will be a big player in the MPG and bad exhaust smell arena.
    You need to have in my mind at least 18 and some engines like much more like 24 initial timing at idle.
    If you have 10 it will cause you to open the throttle plate farther which does affect idle screws.
    What is your idle timing now?
    Dave Nelson likes this.
  10. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    724
    33
    Aug 18, 2011
    Upstate New York
    Yes, absolutely ALWAYS verify ignition BEFORE touching the carb.
