Holley Sniper EFI kit - should I try and self install?
Discussion in 'High Performance Modifications' started by Aussie78Z28, Aug 11, 2019.
  1. Aussie78Z28
    Aussie78Z28 Member
    46
    Nov 17, 2017
    Hey folks. I just ordered the above full kit (includes lines and fuel pump etc) - what are your thoughts on attempting to install it myself or should I get my engine builder to do it for $1,500?
  2. CorkyE
    10,262
    428
    Many of us have installed EFI in our cars, I did the Edelbrock Pro Flo 4, but you're the only one that can answer your question. That $1500 install fee is a bit pricey in my opinion, but I'm on the cheap side sometimes and it does depend on where you're located.
    Aussie78Z28 likes this.
  3. twestrup
    twestrup Member Lifetime Gold Member
    95
    12
    Aug 22, 2018
    Hollister, Cal
    Pretty straight forward install, instructions and videos make it easy. Installing fuel lines and filters take the most time. Holley has a great tech service if you need help.
  4. Rayden2009
    Rayden2009 Veteran Member Gold Member
    111
    14
    May 12, 2016
    Calgary AB
    I would attempt it. Thats a lot of money to be saved and the feeling of accomplishment afterwards is very rewarding. Worst case scenario you fail, put the carb back on and drive to the shop, but thats not very likely.
    Go for it!
  5. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,015
    148
    Dec 19, 2008
    Instructions are easy to read and understand. You CANT mess it up!!!! just take your time and ask Q/A here, Seriously just read the directions a few times and start piece by piece, You'll need those 1500 bucks for new tires afterwards:)
  6. nobreaks254
    nobreaks254 Veteran Member
    492
    9
    Jul 14, 2007
    aberdeen, SD
    Do it your self for sure.
  7. roadrace2
    roadrace2 Veteran Member
    1,665
    38
    Jan 13, 2000
    Earth......?
    save that $1500 and post here after the install and brag about how you aced it! :D
  8. Aussie78Z28
    Aussie78Z28 Member
    46
    Nov 17, 2017
    Thanks guys - I think I will give it a go
    Kricka and QUAKE_WARS like this.
  9. QUAKE_WARS
    2,015
    148
    Dec 19, 2008
    Best choice!!!
  10. Fbird
    3,861
    593
    Feb 12, 2011
    atlanta, ga
    it's pretty straight forward..... making it look REALLY neat is probably the most difficult part.
