Homemade car brake bleeder really neat idea and easy
Discussion in 'Tips 'n' Tricks Topic' started by dave@ztech, Jun 16, 2019.
  1. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
  2. COPO
    18,063
    868
    I have a free one, my Wife. Works well.
    FlaJunkie likes this.
  3. badazz81z28
    17,140
    555
    Las Vegas, NV
  4. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    I agree the nozzle should be set to stream not spray , HAA HA, easier to direct it .
  5. FlaJunkie
    6,272
    185
    Mar 24, 2001
    Rockledge, Florida
    Neat, but how does this work? Is there a cap or something?
  6. badazz81z28
    17,140
    555
    Las Vegas, NV
    ^^ just like a normal bleeder. Seals at the conical when seated. When unseated fluid can only go one way because of the check valve. You loosen the bleeder, jump in and pump the brakes. Jump out and tighten it down. Done
  7. budro6968
    budro6968 Veteran Member
    3,372
    562
    Apr 2, 2016
    Jax Florida
    I just use a piece of clear tygon tube and an empty clear plastic bottle with a hole in the lid. Put a little brake fluid in the bottom to cover the tube. Place it in a concrete block or what ever to keep it standing up. Open the bleeder and pump the brake pedal a couple times to the floor. No mess. Great to recycle the fluid if your doing a complete over haul of the system. Otherwise I just keep the old crap fluid to loosen rusted bolts and nuts.
  8. carr911
    carr911 Veteran Member
    1,875
    414
    Mar 4, 2016
    Tampa, FL
    only to used on cars with bad paint jobs!
