Hood Hinge Spring Installation.....
Discussion in 'Tips 'n' Tricks Topic' started by Twisted_Metal, Mar 21, 2009.
  1. Twisted_Metal
    27,052
    995
    If you've ever pried the spring off of a hood hinge...... You will soon realize that getting it stretched over the hinge again is going to be a challenge. :(
    I've seen where people have used a come-along or ratcheting tie downs to stretch it back to a point where it can be hooked to the hinge again but.....
    I don't own either of these things.
    The thinking cap came out and I figured out I could hook the spring around the axle of my floor jack and a pin beneath the top!
    A few pumps on the jack handle later and the spring was stretched.
    Then.... I wedged a pieces of stiff cardboard between each coil and lowered the jack.
    Slipped the now extended spring off the jack and reassembled to the hinge.
    I still needed to stretch the spring a little bit but I was able to pry the spring back onto the hinge without much effort with the additional length the cardboard pieces between the coils gave me.
    If you have a stack of washers lying around, they may work better than the cardboard.
    Note:
    BE CAREFUL
    when you work with these springs.
    Getting your fingers pinched in the hinge while dealing with these springs can cause boo boos.
    BTW.... This was done on my son's Monte Carlo with a hood the size of a tennis court.
    The springs on our Camaros are about the same.
  2. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,326
    Aug 21, 2002
    Central Coast, CA
    I did EXACTLY that when taking my springs off my hinges a month ago.
    I found an old Ouji board, and cut strips/squares off and placed one between each coil.
    Just put the springs back on yesterday in a few minutes. Hooked spring on hinge, pushed down and held the hinge as I popped out all the lil squares, and voila!
  3. badslife2
    badslife2 Veteran Member
    491
    Nov 11, 2001
    Saginaw,MI
    I've been using one of these
  4. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    A window molding tool??? For hood hinge springs???
    I Gotta ASK HOW???
  5. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    in a pinch i hammered big nails between each coil of the spring to streach it out.
  6. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    I pop them back on with a bfsd (big f-en screwdriver) :)
  7. badslife2
    491
    Nov 11, 2001
    Saginaw,MI
    put the hook part in the spring part that goes onto the hinge,and pull.
    I've used a screw driver as well before.
  8. Twisted_Metal
    27,052
    995
    Camaro springs must be lighter than Monte Carlo springs.....
    There was no freakin' way I was going to be able to pull the spring by hand to stretch it into place.
    If you can do it this way without getting hurt....Congratulations!
  9. K5JMP
    10,216
    9
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    ^ phillips screwdriver. I learned this trick doing old drum brakes back in highschool. Works good;)
  10. krabben1
    8,160
    45
    May 16, 2007
    ( . Y . )Delco
    I just use my fingers.LOL.And POS,I think youre cursed now for the quija board thing.
